i thought so!!!:) I guess it all depends on what cars your comparing doesnt it, sure GOT BOOST's r32 would be more difficult to get down the strip than a r32 running similar times but you said rwd so what about a 454 lx torana with trans brake, auto 2 speed and a high stall, that would be pretty damn easy to get down the strip as opposed to a big turbo'd manual, irs 9sec GTR!!! So i will still say it was narrow minded!!! :)
umm 472bhp?!?!? Is that at the wheels?? 350rwkw?!?!
An RB20t??? Damn nice time even if it isn't.. :P
I almost find it hard to belive it is an RB20t... Care to share the basic setup?!
EDIT: Ahhh it appears its the might RB26DETT. :D
350rwkw isnt that unachieveable, i hope to have that as a minimum once i have finished my rebuild. I currentally have 223rwkw with moderate boost and a small turbo.
It is if you want the motor to be reliable.
To make that sort of power you need huge rev's, lots of lag and lack of streetability.
The use of a small exhaust a/r to reduce lag is also out the window as due to the small capacity of the rb20t you run in to surge issues.
Just as an example an RB20t turbo on a RB30DET will make peak power around 3700-4000rpm. That same turbo on the rb20t made peak power at 7000rpm.
15" NANKANG cross plys.
Were they $90 like I said ??? I hope so. Seemed cheap to me.
fresh and others - Slicks tend to wander i.e. walk side to side as you accelerate down the drag strip. They don't have steel belts like radial tyres to keep their shape and are more prone to shape change during a run which is where this wandering comes from.
If you have radial tyres on the front and slicks on the back, the result is often fishtailing, sometimes quite badly, as the radials drive straight ahead and the back wants to step out side to side.
I don't know about you but I don't like the idea of being crossed up at the end of a run @ 100mph+ :P
Front runners are cross-ply tyres just like slicks that let the front wander along with the back. They are usually quite thin (skinny) to help reduce the rolling resistance of the front end.
Hope this helps.
Adrian
i wish $90 i had to pay $130ea here i couldnt find anyone except 1 dealer and he said he imports them privately. doesnt matter for awhile now as the clutch has said enuff to launching on the slicks. still managed a 11.2 last weds i was hoping to crack that 10.
What clutch are you running...price?
my clutch is a GTR pressure plate (recon) with brass button fiction plate. It finally died last weds. until i started using slicks it lasted quite well. My car makes 100hp more than it used too since cams and turbo upgrade so that hasnt helped the clutch much, i have a HKS twin plate to fit when i get keen enough.
  • 3 weeks later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
