Toyota Soarer 1992 Auto
2.5l Twin Turbo
White 2door Coupe
11 months rego
66000kms (with import papers showing kms)
Full Leather Interior [ bone/tan color ]
Alarm with Remote central locking (there is a tracking device currently fitted but will be removed)
New Tyres on factory 16" Rims
Momo Woodgrain steering wheel
Clarion DRX9675 headunit and 12 stack stacker (duel cartridge)
Tinted windows
Power everything (windows, steering and seats)
lexus rear lip on spoiler
No modifications whatsoever
Plenty of power (206kw factory)
Recent service done about 2 months ago (receipt provided)
has lexus badging front and rear
$15500 located in Sydney
one of the pictures shows the bonnet and has 2 black spots on the bonnet. this is just bat crap. (I took the pics before I washed the crap off) there are no stains on the bonet.
also, the floor mats are not in the pics as I took them out to vaccume and wash them.
http://www.tracka.com.au/Soarer/DSC05812.JPG
http://www.tracka.com.au/Soarer/DSC05809.JPG
http://www.tracka.com.au/Soarer/DSC05817.JPG
http://www.tracka.com.au/Soarer/DSC05818.JPG
http://www.tracka.com.au/Soarer/DSC05825.JPG
http://www.tracka.com.au/Soarer/DSC05829.JPG
http://www.tracka.com.au/Soarer/DSC05830.JPG
http://www.tracka.com.au/Soarer/DSC05834.JPG
Genuine reason for sale
0414088087
https://www.sau.com.au/forums/topic/53759-fs-toyota-soarer-twin-turbo/
ok
I am located in the fairfield area call me on 0414088087
it has leather because whoever originally wanted it put it in! (I thort that would be obvious)
the lexus badges are just to make it look a bit more expensive i suppose. but it came like that when I bought it.
suuuuuuuuuure it came like that :D
what do you mean by that ???
the car is exactly how i purchased it apart from the audio setup and alarm!
so, what I mean by IT CAME LIKE that is exactly that.
this is my 'daily' car that I run around in. the subaru is for the weekends :uh-huh:
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
