I have a stock RB20det engine that has a slight knock in the top end somewhere, louder when the engine is cold. Was told by APC here in Brissy that it sounds like a sloppy gudgeon pin. Motor was running fine before I took it out for replacement. Engine had 60,000km when imported and I have driven it around for 7 months. Turbo is in excellent condition, driven daily at 9psi. Boosted to 14psi at willowbank and ran 13.3sec at 108mph in 180sx. Complete motor with all accessories except AFM $650. Will separate.
also have a turbo that needs rebuild but has no play. Not sure what it is. Was told it is a high flow RB20 with steel wheels, but have also been told it could be a VG30 turbo???? Pics of turbo below next to standard RB20 exhaust housing. $300
Have yellow injectors, not sure what they flow. They are off a toyota engine so you will need an after market computer to run em, but they are a direct fit. $50
Following bits are off a R32 halfcut that I have. (94.000kms)
RB20 auto g/box with flywheel $100
Std auto ECU $150
Complete loom $150
Std intercooler $40
R32 Brake booster $50
R32 cross member (suit RB in S13 conv) $100
R32 KYB front shocks $200/pair
R32 dash and inst. cluster $200
Stock dump pipe and front pipe $50
Air Con complete (looks new) $100
After market s/wheel $50
I am here daily so PM or msg me for info, no emails as my email is f'ed.
Steve
0411 206 780 Brisbane
I'll give you $100 for just the head if the valves an so forth are in good nick. I have no need for manifold, turbo, Plenum rocker covers ect. I can pick up on the weekend.
Ok mate, I have a second parts engine, give me a call when you wanna come down and I'll give you my addy.
Steve
r the kyb shocks with springs?
do u hagve coil packs in good working order?
does the steery have a boss kit?
cheers
Hows it goin mate? Yep the shocks have springs, they are KYB and are light blue with 'New SR SPECIAL' on em. I have a set of coil packs, motor hasnt run for 9mnths and I havnt had em tested. Motor ran fine but had big end noise. They are not off the motor I have for sale. Make me an offer on em.... Not sure what the steering wheel is????? May be a stocko. What does the stocky wheels logo look like in the centre?
Regards
Steve 0411 206 780
    • KYBs are typically twin tube, putting them in the lower tier of desireability. Do you just want to replace worn out ones for the lowest cost? I mean, you wouldn't just replace one end of a car, if the rears are a similar age to the fronts, then they are probably nowhere near what they should be, and likely won't be great against brand new fronts. So, to spend ~$800 on 2nd tier dampers, when you could get a decent set of MCA coilovers for <$4k.....? As to the strut tops. 1st up, the Sparesbox site specifically tells you that they are not correct for an R33. Beyond that, why do you think you need them?
    • That's not very Toyota of the Toyota!
    • Bringing an old thread back to life Looking to put some new front shocks in the r33Gtst and the KYB still look ok for a road car. Unless there are any other options aroind that price $200 a shock?  I’d like to replace the strut tops also, is this the correct KYB no. For the strut top, KSM7124?  https://www.sparesbox.com.au/products/kyb-strut-top-mount-ksm7124?srsltid=AfmBOoq-HDru8wSlLnQrhU9gCw_uYdKg8gUQzONY-EQOdnI5iXOWEUjY 341287 appears to be the front KYB shocks part no.  thanks all
    • LandCruiser used to get a fluid flush every 12 to 18 months.   Only because it was about that often the electric motor on the master for brake assist kept dieing and needing to come off.
