I have a stock RB20det engine that has a slight knock in the top end somewhere, louder when the engine is cold. Was told by APC here in Brissy that it sounds like a sloppy gudgeon pin. Motor was running fine before I took it out for replacement. Engine had 60,000km when imported and I have driven it around for 7 months. Turbo is in excellent condition, driven daily at 9psi. Boosted to 14psi at willowbank and ran 13.3sec at 108mph in 180sx. Complete motor with all accessories except AFM $650. Will separate.
also have a turbo that needs rebuild but has no play. Not sure what it is. Was told it is a high flow RB20 with steel wheels, but have also been told it could be a VG30 turbo???? Pics of turbo below next to standard RB20 exhaust housing. $300
Have yellow injectors, not sure what they flow. They are off a toyota engine so you will need an after market computer to run em, but they are a direct fit. $50
Following bits are off a R32 halfcut that I have. (94.000kms)
RB20 auto g/box with flywheel $100
Std auto ECU $150
Complete loom $150
Std intercooler $40
R32 Brake booster $50
R32 cross member (suit RB in S13 conv) $100
R32 KYB front shocks $200/pair
R32 dash and inst. cluster $200
Stock dump pipe and front pipe $50
Air Con complete (looks new) $100
After market s/wheel $50
I am here daily so PM or msg me for info, no emails as my email is f'ed.
Steve
0411 206 780 Brisbane
I'll give you $100 for just the head if the valves an so forth are in good nick. I have no need for manifold, turbo, Plenum rocker covers ect. I can pick up on the weekend.
Ok mate, I have a second parts engine, give me a call when you wanna come down and I'll give you my addy.
Steve
r the kyb shocks with springs?
do u hagve coil packs in good working order?
does the steery have a boss kit?
cheers
Hows it goin mate? Yep the shocks have springs, they are KYB and are light blue with 'New SR SPECIAL' on em. I have a set of coil packs, motor hasnt run for 9mnths and I havnt had em tested. Motor ran fine but had big end noise. They are not off the motor I have for sale. Make me an offer on em.... Not sure what the steering wheel is????? May be a stocko. What does the stocky wheels logo look like in the centre?
Regards
Steve 0411 206 780
    • f**kin' yikes! That insulation is the shittest stuff I have ever seen. You need to do an insurance job on that f**ker, pronto. WRT to the washer cover, I would have said that there'd have to be some at a wrecker, then remembered that it's a BMW, and reasoned that every single wrecked one would have been tailgating and so the front end would be trashed.
    • Oh and I lost my headlight washer jet cover!
    • Ok, so I got myself some X1 wheels really cheap to try out, they're a bit different and I like them but they're really narrow (18x8) they are available in staggered 18x8/9 also but really hard to find.  I kinda dig them, but not as much as the F10 19's I usually run, so these go into the wheel pile.         As I mentioned in another thread, I got a new exhaust. It's an off-the-shelf stainless one that fits OH-KAY. I don't love the tips size and how far they come out the back, I think I might cut the tips off and replace with some smaller (~3") ones that don't extend as far. It sounds really good though, I'm not sure if its just in my head but the car feels a little quicker, more responsive.      I fitted an eBay special front lip. Surprisingly it fit perfectly and all holes lined up. Its a little rickety but I haven't put any double sided tape on yet, I want to clean the front bar up where it has scraped the road a lot and fil in the number plate holes (or, get body coloured wrap to cover them - is this a thing?  I'm not sure if I'll leave it gloss or pain it matte. I really like it though, I don't particularly like the front bar without it, I don't really like the M-Sport and to get anything else is just too expensive. That said, I might need a new one now anyway as I dropped the car onto the jack after forgetting to put ramps under the front wheels. It bent a lot and while it did go back to normal after I got the car off the jack, I do fear I have not done it any favours.    Lastly, my headlights died. Different problems in each. They have gotten much dimmer over the past year or so, I put new (uber expensive) OSRAM bulbs in them but to no avail. One of them pointed at the ground and the other just kinda did its own thing with light working sometimes. Yeah, check this 18 year old BMW headlight wire. I reckon I know why they were stuffed.            BTW, the yellow and black is the power to the Xenons. Yikes. I hunted around an researched my options here. I would have loved to just get a replacement harness but not a thing. My car has adaptive headlights, that is they rotate left and right with the steering wheel. Good condition used adaptive xenons were over $700 each, non adaptive were around $400 each, but I couldn't help but think that they're all around 18 years old now, surely they'd have the same problems. So I looked at newer LCI headlights but they were even more expensive and I couldn't confirm that they'd be plug and play with lots of people having lots of opinions so not worth the risk.  I ended up getting brand new Chinese headlights from MARS. They're very close to OEM with only the angel eyes being a bit different. I didnt want crazy turn signals or sharp DRL's or anything. Not my bag.  They're not adaptive, I thought thats a feature I wouldn't really miss. So I coded that out.  The lights are awesome, they look so nice and they take so many years off the car. The angel eyes look great and the headlight brightness is ridiculous. I was so used to the old ones, I didn't realise just how bad they were. The new ones use the OEM bulbs, Xenon ballast and leveller motor which I was happier with. The only issue with them is that the rear cover is held on by SEVEN screws. This will be a nightmare to get to and open when I need to change bulbs.
    • Now that you mention it I can see those too. More subtle. The lighting and low resolution makes it hard to assess super well what's going on but what is visible is bad enough to pull the motor.
    • I feel like this is due an update
