NISMO,
If I was to guess at it I would say that the alternator bearings are on the way out!!(these can sometimes make the exact same sound that you describe so I would check this first) But to check it you would have to remove/loosen the belt to see how easily the alternator spins to make sure!
MEGA
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-85169
hey guys i got a bit of the same thing with my car, when it is first turned on its has a whining noise, this goes away after about 4 mins.
and what bearing do you think will be fked if when the clutch is out there is a loud noise but when the clutch is in it stops ?? ideas anyone
thanks
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-87643
There was a thread on this a while ago, but no resolution.
I have the same problem.... When its cold, you start the car, and you get a screech (intensity of sound depends on how cold it is), and it will last about 1 - 2 seconds.
I've had this prob for over 6 months now, and I have no idea what it is. As it only does it when i start the car, and the outside ambient temeperature is low, AND it only lasts about 1 second, I haven't bothered to fix it!
And no it's not the fan belts,
Doubt it is the alternator bearings, as it would do it more consistently...
Can anyone else that has this problem, please tell us if you also have a squeeky clutch! As in does your clutch squeek sometimes when you depress the pedal?
Zahos
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-88808
have a read through this thread adam
http://forums.skylinesdownunder.co.nz/show...=&threadid=7186
I'm just trying to figure out if the 2 probs are related....
Anyone else that has the noisy start up problem hav a squeaky clutch? Even if you have one prob, and not the other, please tell us, and how long yoou've had the problem.
Thanks
George
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-88947
bugger everyone has the same thing here
we need to have a skyline meet lol "maintanence meet"
we can all do our bearings and squeaks at the same time :)
like a dyno day :)
might aget a quote on getting the throwout bearing...or even get someone to look at it and tell me what they recon it is
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-88973
Zahos,
I have a auto(Not for long though) GTS4 and I have experienced the same sound on start up (only twice so these would have been cold outside and that the car hadn't been started for one week) so I don't think that the start up noise is related to the manual gearbox.
It seemed to come from the front of the car where the alternator is located?
It also happened after I fitted a new fuel filter and had to clean the engine bay again I thought that a unsealed bearing had got a bit damp because I only cleaned the drivers side of the engine bay.
I can't actually diagnose the problem because it has only happened to me a few times and is inconsistent enough for me to leave it alone until I put in rb26.
MEGA
where is NISMO?(the one who started this thread)
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-89363
Thanks for that Mega!
So now I'm left with no clues as to what it could be! I would think that if it were bearings that it would do it more consistently? A friend had the bearings go on his air-con, and that made bad noise consistently, wouldn't the bearings off any component working off the fan belts do the same thing if they were buggered?
Anyhow, summer is coming so I guess I wont have to worry about this one for a while!
https://www.sau.com.au/forums/topic/5380-noisy-start-up/#findComment-89582
    • The cam I am actually putting in (a few posts up) is actually smaller than my current one. At least duration/overlap wise. All the chop stuff I hear just sounds like an engine running badly, because it is. I then envision driving it around in 1st gear and being massively sad about it bucking to the beat of said chop. There is an idle video of someone with a similar cam floating around the internet, but mine is a custom cam (so is his) so it'll never be the same, plus the fact exhausts are entirely different. What I want to do is put some bullet mufflers/race mufflers in to replace a couple sections straight pipes that currently replace the two extra cats that I don't need. But this is even further down the line!
    • I can tell you now, when the bracket that the little hydraulic ram attaches to snaps, with a subframe, and V8 from an AMG C63 on it, it sounds like someone letting shotgun off right beside you. It leaves your ears ringing, and a huge thankfulness that you never ever put a body part under something heavy that's only supported by a hydraulic lift...
    • Still not a guarantee fix. I used a high quality butyl-mastiq (the black goo that's not really silicone nor polyurethane, same stuff they use from the factory that just spreads out like melty cheese), and I still get lots of water on both sides of the trunk when raining or washing the car. I also suspect the factory spoiler rubber gasket might not be sealing well, so I'm thinking of adding a thin layer of grey silicone around the bolt holes on both sides and see if that's where it also leaks from. The biggest issue is that these cars don't come with a drain hole on each side like other coupes and hatchbacks.
    • I hate it, but maybe he could paint it Monster jam style and call it...godzilla?
    • Would seem to me to be appropriate to go GTR style bar. There are options with and without N1 vent holes, with the GTR lower lip integral (because FG copy). https://justjap.com/search?q=r32 bumper
