pHAT r32: WHO CARES WHAT THEY LOOK LIKE LOL :(
heres what u have to look foward to once they are set up:
after fitting the cams and doing a base run at zero zero cam setting I spent about 3 hours tuning the gears alone and achieved 20kw at the top end, 12% more torque over the entire rev range (thing about that for a sec) and spooled the turboes up 500rpm earlier> try 14PSI at 3400rpm...not bad for 3 hours dyno time and a few burnt fingers :)
Well worth while getting them set up rather than just looking at them. My settings finished on 4 degree retarded on the exh and 2 degree adv on the inlet. The main point here is the lobe center angle has been increased by 6 degrees thus increasing cylinder filling efficiency.
Mike
may i ask which cams you were using cheers
:P
  • Replies 131
Tomei 9.15mm 260 duration...a very nice cam for a std GTR...Also just a note..upon setting up the head during my recent rebuild I watched the machinest setup cam lift and spring clearences etc ...worth noting is that the 9.15mm lift is the biggest that you can go comfortably with the std GTR springs due to coil binding problems. Anything over about 9.8mm and the coils become bound up...not good. I fitted slightly heavier, around 10 lbs when fitted, springs with less coils so I can fit a larger lift cam later on if I need to.
cheers Mike
  • 2 months later...
How much does a set of Tomei Poncams for an R33 cost? And at what stage of modification do you suggest you get them (Do they provide much benefit on stockers, or after exhaust and pod, or after major engine mods etc) or can you get good gains anytime?
  • 2 months later...
Hey guys, reviving the dead thread :P
Whats the driving/performance differences between the Tomei Type A and Type B cams?
Type A 260IN / 252EX
Type B 260IN / 260EX
Does running the higher exhaust duration ( type B ) effect low down tourqe?
I'm just trying to decide which set to get.
I'm after a nice smooth tourqe curve (street car)
Thanks
Edited by CameronBNR32
Hey guys, reviving the dead thread  :)
Thanks
i'm pretty sure it's the other way around mate. type a is 252 degree INLET. this is because of the theory that you can 'over cam' the inlet on an RB26 and a mild inlet cam matched with a slightly wilder exhaust cam is a good match for a street car. can't say i've tried it in practice though.
sorry beerbaron but the cam duration mentioned are right
http://www.tomei-p.co.jp/_2003web-catalogu...r_engindex.html
and i believe the opposite that rb26 are normally over cammed on the exhaust not the inlet as the manufactures spec cams and some aftermarket cams combo like this combo we are looking at ,run a longer inlet than exhaust for street use. To give the best combination of power and responce.
But all that said and done the 260/260 9.15mm poncams are a awesome bolt in combo and i believe the best bolt ins on the market.
Currently i'm looking at running some procams with high lift profiles and different duration combination to see how much can be extracted from my GT2560Rs turbos last dyno sheet was 529.4rwhp(397rwkw) on the poncams and i know that TWO.06l is running poncams at 442kw on HKS 2530s (but serious boost and c16)and 10.38 1/4 mile (thats a seriously fast low mount combo)
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
