  • Replies 49
Here's that site I couldn't find the other day with sound samples of various bov's. The sound quality isn't too great but you get the general idea. Personally I think the GReddy Type R sounds best, but I don't know if that's just because my car came with one and I'm used to it, or the previous owner thought it also sounded cool and I was therefore lucky to get it :P
http://www.alltrac.net/tuning/blowoffvalve.html
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-82852
Hey that supra wastgate link- the fluttering in between gear changes:- does anyone else think that sound is purely the chopping sound from the turbo due to reversion?!
Many ppl think that is a blow off sound, but if you think about how most of them work, it dosnt make sense if they made that sound- the valve would have to be bouncing open and closed!
In between gear changes, the pressure in the inlet tubes suddenly increase due to the throttle body closing, which usually pushes the blow off valve OPEN. As soon as its spring pressure overcomes the inlet pressure, the valve closes right? and once its closed its not gonna open again anless you boost it and back off again.
Please correct me if im wrong, but i think i may have it figured! Fluttering= reversion -not blow off sound??
cheers
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83299
thats interesting about the piping theory, as mine only made the sound after the FMIC went on.
I reckon i have the answer though ;) :-
How about the fact that with all the new piping and a big cooler core, you have more than doubled the volume of air in the inlet tract, so this extra air, if not let out by the BOV, will have to work its way back out through the turbo (flutter) and out the air filter, just as classic reversion!?
Thats why most skylines flutter at low boost, as the pressure was not high enough to trigger the blow off, and hence, puh puh puh puh puh puh(flutter).... This is the sound that VL turbos WITHOUT BOVs make really well! :)
Exstatic,
Are you saying that the factory BOV's are adequate? or that you dont need a BOV at all?
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83576
This is my undersatnding (and experince) of it:
If the BOV is too tight (or simply not enough pressure to open it), the air will travel back through the turbo, get chopped and make the flutter.
If there is enough pressure to open the BOV (or the BOV is really loose), you get the psshht sound.
SLY33 I think you're on the money when you say...
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-83669
my friend has the flutter sound on his s14
he just disconnected the vacuum hose on the standard bov (therefor bov is not working) and i guess the air gets pushed backwards thru the turbo making the flutter sound. the sound really only works if you rev alot.
i also tried it on my 33 and it made a similar sound.. not exactly the same. but after boosting it and i come to a stop the car stalls. getting mixed air/fuel i think
wonder why skylines will stall and 200s dont
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88121
Yeah the car stalls due to reversion. Air passing back out through the turbo cools down the element on the AFM causing the engine to run ruch.
I beleive there are two causes for that noise both result in reversion.
1. BOV to tight, causing air to get bounced back from the throttle body then through the turbo and "getting chopped" by the compressor blades.
2. FMIC installed, volume of air is increased substantially and air cannot escape out of the BOV fast enough causing it to reverse back into the turbo then once again air gets the chop.
Doc
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88290
nah read my earlier post
my friend disconnected his vacuum hose that runs to the standard bov. therefor making it not work creating reversion and fluttering.
i tried it on mine too, but after giving it a hit and coming to a stop it stalls.
both of us do not have any aftermarket bov.
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-88340
my R33 has a K&N pod filter, and it makes a fluttering noise when I take my foot off the pedal. Quite a nice sound really.
I've also got a Greddy Type S BOV and it makes this "lazer" high pitch noise when the car is on boost (when changing gear). Both goes really well together...
CBB
https://www.sau.com.au/forums/topic/5381-bov-noise/page/2/#findComment-90597
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
