I need an afm for my rb20det and i've heard that the z32 ones are a popular item. Just a few q's about them...
1. Are they a direct swap with the std item (loom plug is the same and plugs in??)
2. How much do they generally go for 2nd hand?
3. what beneifits do you get with using a z32 item?
4. I take it z32 is off a 300zx?
https://www.sau.com.au/forums/topic/53817-z32-afm/
1. They are the same but you need to wire up a new plug wich is piss easy.
2. I got mine for $250 but they do go from $250-$350 from what i have seen.
3. Once you max out the RB20det AFM it's hard to tune it so bring on the Z32 that is all.
4. Yes of the twin turbo one.
Wiring for Z32 Maf into GTS-T
Z32 terminals are lettered A Thru to F, total of six terminals of which 5 are used on the Z32 and 4 on the GTS-t.
Working from A upwards as follows:
A: do not use
B: connect to Black wire on GTS-T MAF loom
C: connect to black/silver
D: connect to white
E: connect to black with white tracer
F: do not use.
Use a VL AFM plug if you don't get one with the Z32 coz it's the same.
https://www.sau.com.au/forums/topic/53817-z32-afm/#findComment-1054660
