hi guys :)
ok, i have an OS twin plate clutch, and i was wandering about something..
whats rate on that? how much could it handle..
also, and this is the important Q :
a while ago i heard that u can rebuild ur OS clutch by Exedy!
is that true?? iive been trying to remember where i heard that but no use :D
any idea???
https://www.sau.com.au/forums/topic/53819-os-exedy/
mate there is an OS dealer in Aus too. www.otomoto.com.au
Rebuilding your OS clutch with exedy bits will not give you a new OS clutch. Just like rebuilding your HKS turbo with Garret parts does not = a new HKS turbo. If (when) I need to rebuild my OS twin plate, I will buy the new OS parts for it. no stuffing around.
Richard
https://www.sau.com.au/forums/topic/53819-os-exedy/#findComment-1057028
hi guys :D
1.whats rate on that?
2.how much could it handle[/b]..
3. a while ago i heard that u can rebuild ur OS clutch by Exedy!
is that true??
any idea???
1. there are two types of OS Giken twin plates, one is rated at 550 bhp and the other 700 bhp in a GTR (4wd and extra weight) so slightly more for GTST (2wd and less weight).
2. lots, we have had 650 bhp for 2 years in a circuit race GTR using the 550 bhp OS twin plate.
3. my local clutch shop put new linings on the OS Giken clutch plates, no problems.
Hope that helps
https://www.sau.com.au/forums/topic/53819-os-exedy/#findComment-1057767
Hey SK, how did they reattach the clutch plates, and what material?
No one down here has the 1mm thick plates.. or know how to attach it?
The OS Giken clutch linings are bonded onto the disk on the road (lower power rating) spec multi plates, they also have coil springs for taking up the shock loading. The race (higher power rating) specs have no coil springs. The splined centre is rivetted to the disks. So the process is to drill out the rivets, keep the spined centres and replace the disk and linings with new parts. The equivalent Daikin parts fit pretty well.
Hope that helps:cheers:
https://www.sau.com.au/forums/topic/53819-os-exedy/#findComment-1058651
    • I don't know specifically. I *do* know that it is very likely that historically most/all undertray replacements remove the inner liners and people just run without them. When you are hectic (or serious) enough to really want/need a different undertray, you are probably also running wider, taller or different offset wheels and the guard liners are the first thing that rub (or as I said in the other thread, they blow out at high speeds anyway) Of course, that is before the pricing went nuts on R34s, nowdays it is much more likely people want/expect to retain the liners to protect their overall investment
    • Haven’t had a chance to drive it properly yet. It was rwd and pissing down rain when I drove it home and now it’s in the air with the so I can change the oil. Going to do the  gearbox oil while I’m at it as well, may even do the diffs
    • On 12th June, the mechanic could not figure out what the issue was, but the car seems to be flooding with fuel. He was suspecting the tune, thus referred me to a tuner. Although the tuner is not familiar with Nistune, last Monday (30th June), he came over to try and re-map it. Despite the tuner trying to completely stop fuel, it kept sounding like it was pushing fuel. Tuner ended up suspecting either the ECU or Injectors. I do not believe the ECU or Nistune is the issue, as the Nistune software reads and communicates properly. Today, I removed the (new) injectors to see if they are clogged or leaking. Surprisingly enough, after those 3 days of driving, injectors 2 and 3 look very blocked. You can see the difference in the picture. I blew a bit on 3, that is why it doesn't look as clogged as 2. I am still unsure if this is what is causing the no start issue, but I am now feeling that I may have bought the injectors and Nistune without the need to do so, as the problem seems to be coming from somewhere else.
    • haha this shit box doesn't drink coolant, for now       Let me guess, they make heaps of power, use the car for straight line driving and don't care about noise
