Stop all this crapping on about what you will or won't do over the quarter based on a dyno.
Take it to the strip, till you do an actual 13 you can say nothing. Tell everyone you expect 14's so when you run 13's you can act pleased.
My old R33 gtst ran low 13's with less work on horsepower output and more on maximising engine response, something a dyno doesn't show you. You may like to spend some time on traction issues too. You don't need that much power to run low 13's just good average power.
I reckon if people like guessing about 1/4 mile times so much based on dynos someone should start taking bets. I think I'd do pretty good business as a bookie. :(
https://www.sau.com.au/forums/topic/53874-14-mile-time/#findComment-1056872
I ran a 13.6 with 155rwkw in my R33 gtst, the turbo wouldnt hold boost, and the clutch was slipping, this was at WSID, if I had a scanner I would post it for you.
Come to think of it I ran the 13.6 with only 3in zorst from turbo, and EMS stinger, bleed valve set for 15psi.
https://www.sau.com.au/forums/topic/53874-14-mile-time/#findComment-1057205
I reckon if people like guessing about 1/4 mile times so much based on dynos someone should start taking bets. I think I'd do pretty good business as a bookie. :D
like i said it done a high 14 @143 so anytime quicker than that will do me 4 now and with new reading i hope to get a mid- hi 13 ,just thought some guys in here had a rough idea on what it could run ,and they have thankx guys, (didnt i say there is no strip here ) but it wont be long wsid is looking the closest
https://www.sau.com.au/forums/topic/53874-14-mile-time/#findComment-1057775
