Got a DEAD stock R32 GTR for sale
*DEC 1989 build (one of very few in australia, for the time being)
*56,000km on the clock (cant prove its right, but it looks like the car has very low km)
*Gunmetal grey
*Had engine rebuild in japan 11,000 km ago (why i dont know but it has!)
*Just freshened up the breaks (machine, and bendix ultamate pads all round)
*Just rebuilt clutch master cylinder and booster
*Just changed all fluids and filters top to bottom
*Rego for 10 months
*Everything works (excpt no a/c gas as it was degassed in japan, but ac does work)
*NO MODS!!!!!!
*Top of the range alarm with 3 point immobilizer just installed (works GREAT!)
Pics at http://chubby.nameserve.org/~mypics/gtr/
only probs with the car are:
*slight exhaust leak, Pretty sure its the gasket from the cat to the rear section of the exhaust
*wear on the drivers seat (very common)
*dint on left front guard can see in the 2nd pic, but only notice it if your looking for it.
Very nice clean car
$22,500
Sydney 0410496449 Jacob
Reason for sale, lost my licence can show paper work :D
https://www.sau.com.au/forums/topic/53907-r32-gtr-89-55000km-cheap/
id probably remove what alarm was just installed on it from this thread in the interest of the person buying it :) trust me... we arent the only ones that patrol these forums
  • 4 weeks later...
Thanks guys! sorry about the link, better pix at http://chubby.nameserve.org/~mypics/gtr/
The price is VERY reasonable for so very few little probs, drives like a DREAM.
Lost my bloody licence again thats why im selling up (can show letter if you like)
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
