  • Replies 381
lol i dont drive it? whats in the work carpark at the moment? what have i been driving around for the past week? (to and from mechanics of course... :()
like always denham ur talk is cheap and ur clothes cheaper. why isnt there a retarded smiley? i have a pic of denham somewhere maybe i should make one :D
wow now i am hurt :)
R u buying my rims before calder or what? :shake:
ps, ur mums even cheaper
u sik fark.. u have issues...
almost as bad as ADZMAX.. i said almost
The only issues I have is when co(k smoking VL Speed boat drivers like you think thet your glorified barely holden together commonwhores are real "Street Machines". Oooooo look out, is it a BOGAN, is it Nick Giannopoulos, No! It's a VL driving, keyboard warrioring, full sick dragging morron!
Oh and just so you feel at home on our forums here's a picture for you scrap book.....
:)   man have u got a massive :headspin: or something..... i know it's worked just curious as to what dont gotta tell all ya secrets... and are u running LPG or Fuel????
LPG no ur talking bout my mate gas747
no im not running LPG
yeh only got 183rwks :-) ur rite nik
few lil things done
turbo
exhaust
etc :-)
wont be looking for a fast time first time out..
will just be playing with a few things first couple of runs..
lol u big mean street racers u..
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
