  • Replies 381
Im gunna go calder park on friday just to race Ni in his Cefiro.
Good luck mate, I hope your VL is good.....  koj si ti ?
just make sure u dont rock up this weekend as stated in previous posts... friday after :cheers:
Thisss khuunnnttttt.. i took out my tail shaft last nite... haha had a bit of problem with it
so we on for this week or next?
so i know if i shoudl hurry da fark up or not :-)
ahahahaha yeah this week :D
rigga... im hoping for low 13s or high 12s... providing i can get traction i would say thats pretty realistic.
:confused: you mean the ceffy is only a match for my barely modded 33? This is going to be fun :D
Make it next Friday coz I is a poor fark this week :(
    • Did I tell you I really love skylines ? ! ‽
    • Ha ! Did mine as well. Used a Z hose I got at Supercheap and cut out what I needed. Then while everything was off changed out the water heater control block and the heater supply hoses to silicon on both sides. While attaching said hoses to the plastic hose fitting that goes through the firewall to the heater core they crumbled due to age. Got new heater core supply pipes, de gassed the air con took out the glove box pulled out air-conditioning fan unit and took out the heater core went to change out the busted pipes and went nope ! Went and got a brand new heater core, attached the heater core pipes, put the air con fan unit back in, re attached the new silicon heater hose, put the air conditioner fan unit back in got it regased annnnnnnnnd Bob's your uncle ! 5 minute job really ! AND I AINT DOIN THAT SH*T AGAIN ! !
    • just under 600rwkw , 1650cc,  pump e85 ~80% duty   Your 1200s won't make it safely
    • What’s the labour like on it? And how much better is it than the stock one? Guessing a lot stronger.    I would be shipping from Japan to Hong Kong so not that bad…
    • It is the entire transmission BUT you must swap in your old transfer case. There is no transfer case on the back of it. Comes with throwout bearing for the OEM pull clutch and Super Coppermix Twin pull clutch, new clutch fork, pivot, cotter pin, washer, and clutch fork boot as well. Keep in mind shipping is killer for such a giant piece of metal. I got mine from Trust Kikaku USA which shipped a container full of them to Long Beach and I had to pick it up from their warehouse.
