lol and he stays home with the baby... hahaha im sure that will go down well :D
man i had plans for after the drags too... was meant to be going out... now i'll be too stuffed after work to do anything other than go to sleep.
  • Replies 381
,.|.. o_o
u know what makes it even worse??
next week i have to work 4-12... so another wasted friday night
the week after i have to work 6-2am!!!
*** man.... i need a new job
yeah mate im scared of someone who doesnt even have their licence.
u see... some of us work in these things called full time jobs... if u wanna pay the $200 i miss out on for not working friday i will be there with bells on
if anything u should be glad... incase u end up being beaten by a std engine vs ur modified one.... ouch that would have to hurt the ego.
just make sure once u dont do too many runs... u will probably end up having to rebuild the engine otherwise... we all know how rotors are :)
just make sure once u dont do too many runs... u will probably end up having to rebuild the engine otherwise... we all know how rotors are ;)
oh my what was that thread about an rb25 droping its guts the other day? does this mean all rb25's are weak and break easiliy? no, so the same goes for rotors, dont generalise :)
Yeh your right.
anyway, most rotary's are stronger then a piston... with NRC seals you cant go wrong, bullet proof.
if anything your RB26 will blow since that hasnt had a 1,000klm old rebuild.
you honeslty dont know anything about rotary's from your words.
il line up a rotor..
yeh should be there friday nite .. just gota iron out tail shaft problem..
my cars green ;-P old man green.. got no cooler or nothing.....showin...
REDFC u running friday nite?
any one know da weither?
is it gonna even be worth getting the thing ready?
Yeh your right.
thats where ur wrong... seeing as 2 of my mates have 10second street rotors which have been rebuilt 5 times each.
one RB25 drops its guts out of the plethera of rotors that do... mind u most of the rotors are puting out massive times and worked quite extensively... so i guess that doesnt help lol
sunny and 25 :)
should be a nice cool night too so good conditions for it
    • Any number of different ways. Have the coils draw sufficient current to provide contact wetting. Use different contacts in the switch, either by material or design, better suited to the low current drawn by a relay coil. Etc.
    • Hmm, how does the R34 manage to have headlight relays then without getting excessive carbon buildup on the headlight switch contacts?
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
