Hullo,
I've been practising the breaking drift a bit and it seems im on the threshold of the car going sideways, but by the time i feel it ready to come out im going way too slow so i just bail... now currently my susp setup is horse shit, really soft stockers, now the thing that i wanna know is, wouldnt soft susp be good for shifting the weight, because it moves so feely or is stiff susp better because you can only shift it to a certain point untill it slides out, giving the car a much lower slide / traction break threshold ?
Thanks!!
https://www.sau.com.au/forums/topic/53972-breaking-drift-suspension-setup/
soft suspension would help to transfer wait forward, however it comes back to the whole pendulume effect. when stomping brakes at high speed with soft suspension, the car will nose in, the back lifting and wait will tranfer forwards. also to with hard susspension weight will tranfer, it may not look like weight is transfering as much but thats because body roll in soft suspension is missleading in appearance. in hard suspension the weight transfers quickly and isnt dampended like it is with soft suspension. when braking with hard suspension its more quick an accurate transfer. sorry blaaahhh on for ages
Thats it, if you can't afford new stiff suspension, maybe use adjustable swaybars to stiffen the rear suspension right up and so that less weight shift it taken up by the rear suspension, thus forcing the rear to slip not grip!
LOL - my mate shamed a few people by out drifting them in a stock e30 325e - with 64rwkw ... so you can make it happen without spending on mods if you know how!
muahahah 64rwkw thats money well spent :P the $200 datto had 49rwkw....those extra 15 cost a fiar bit
hehe, thanks for the response!
i glady appreciate it... i reacon it would be wise for me to learn with shit suspension so when i do get decent springs or coilovers i can relly apreaciate them and use them to thier limit.. thankyou!!!
Hmmmm... learning to cut with a blunt knife...
I really don't know if it is good. Learning without a lot of power I agree with (stops you from being a straight line hero) but good suspension means you are learning to drive, not to compensate for the car being ghey.
good point... but wouldnt learning the limits of a poor setup help you take advantage of a good setup..  and exploit it for maximum drifts?
Well the best drifter I know learned in S13 with craptacular suspension and horrid wheel alignment (mostly due to hit gutters). So he seems to think you can do it with stuffed stock suspension.
I have only ever slid around a S14 with stock but fairly new suspension which I found very roly poly but very easy to slide. The drivers I have seen with crappy suspension that were drifting pretty badly instantly were better with new suspension and are now extremely good.
So yeah maybe bad suspension is a good training tool. Hmmm, hard to know.
Yep... compared to Japan (almost) everyone is very slow so they can't use the momentum to come into the corner properly. Speaking to the Japanese driver's they said they only used the handbrake to hold the car out sideways after it is already there
silver e30 at wakefield
yea i remeber that guy
quite dangerouse on the race track
ran me of the road
someone should tell him when overtaking on the race track in a straight line to only cut infront after he actually passes you as opposed to cutting in front and running you into the dirt.
im glad i was in a mates 808 ... maybe should have let him run into me
nice bloke besides that
hmm i'll let him know fatz... he gets a bit of tunnel vision in a race car!
Sorry mate!
funny thing is that car is sooooo slow in a straight line, cant believe he overtook you LOL
meh everyone knows pete's a pu55y on a race track, no wonder he got past :P
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
