If I got that email, I would have ignored it straight away. Someone calling a car goods is just stupid. Fair enough if it was like an air filter and a steering wheel and horn button, that is "goods".
I wouldn't give him ANY information. He might even be someone from australia just pretending to be from overseas but really in the local area and wants to steal it.
I'd be worried.
  • Replies 40
Yep, gezzz those Nigerian scammers are d#ck heads, they speak another language, the way they compose their emails, pick them out from a mile away. Yeh i wouldn’t reply or send any details to the dodgy f#cker... Wish i was a cop & had some Nigerian scammer f%ck try something on me...
I'll tell you right now thats a cut and paste job for random scams and probably automated anyway (ie its probably not even a person cutting and pasting but rather a script or program).
Parts dont match up, the order of the emails that he/she/it is sending are scripted and generic as they dont even match what you have said (and have a few other tell tales).
Anyway - ignore that shieeet and get back to business. IT IS FAKE FOR SURE.
if your using outlook bring up the email choose edit then options i think it will have the mail header down the bottom or if its outlook express bring up the email click on file then properties and then goto details it will look like this:
Return-path: <[email protected]>
Envelope-to: [email protected]
Delivery-date: Wed, 20 Oct 2004 13:30:32 +1000
Received: from [67.18.170.186] (helo=victorinox.sanitytechnology.com)
by postoffice01.mail-hub.kbs.net.au with smtp (Exim 4.34)
id 1CK7B8-0006HB-7h
for [email protected]; Wed, 20 Oct 2004 13:30:22 +1000
Received: (qmail 19080 invoked by uid 1000); 20 Oct 2004 03:30:17 -0000
Date: 20 Oct 2004 03:30:17 -0000
To: [email protected]
Subject: Reply to post 'I thnk I am being scammed - for my car??'
From: "Skylines Australia Discussion Forums Forums" <[email protected]>
Message-ID: <[email protected]>
X-Priority: 3
X-Mailer: vBulletin Mail via PHP
Content-Type: text/plain; charset="ISO-8859-1"
Content-Transfer-Encoding: 8bit
Exactly what I was thinking. Nigerian scammer.
Make him send pictures first. :P
- J.
Yeah someone did this with my 300zx was for sale - its a Scammer ..... just tell them to phuck off.
Nar reply back saying you've reported him to the computer crime squad & he'll be contacted very shortly....
I know in this case that he has replied back more than once and has been emailed more than once, but I think there are scenarios where the email address that it says it came from is also just picked up by a 'spider'.. ie its just an email address off someones msn list or something, so in some cases replying to that email address could be to an innocent person?
Also if you do reply to spam doesn't that just confirm to the spammers that your email is still active, so they will keep spamming it??
It definately looks like an automated response scam, it never mentions anything specific about your car or even "your country." This message could have been sent to every person advertising on Carsales or whatever.
Id even go as far as to complain to carsales, or at least tell them about it, see what they can do to stop it happening again.
Yeah, probably a good idea. Report it to carsales and ignore the guy. If you get any more emails just say someone offered a substantially better price and he is too late, the car is sold.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
