I had a tomei and jun one side by side... ended up going the jun as the 'doors' are hinged metal not rubber and the jun looked like it allowed more flow into the 'trapped area' (the doors were physically larger).
Also with the jun baffles, it retains the stock 'oil sump cover' that goes over the sump. This has specific cuts and galleries in it so the oil flicking off the crankshaft and dribbling down will 'recirculate' back into the sump. The tomei kit replaces this cover with its own which is completely closed.
Measure twice, cut once. :chop:
I agree....youd wanna check what it actually is....had the same talk to a guy that supposably builds engines the other day...he said "plastigauge....thats old"...but after i said "why not check it hell i check everything at least twice" he started to back pedal after an onlooker(who was an engineer) agreed
the only time i would use plasti gauge is if i was doin bearings in place and couldnt really get a micrometer in there, im sure most reconditioners would cringe at its use, i agree measure twice cut once but measure with the right tools. Also the way they mount and measure with that digital bore gauge is not that accurate, i would use an inner mic and measure that with the outer mic that id used to measure the journal so your taking all your sizes off the one tool.
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
    • I just quote the Rolling Stones. Paint it black.
