  • Replies 70
Sqizz
I actually did tape it last night, but not for me - its for a friend (hahhahahh).
All the chicks are HO, except Shannon the areobix instructor. Shes a hotty. Watched her last night in the shower shaving her guttered eewok...
DAM HOTTY
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1319
hmmm nice hi jacking guys.
check out the other thread here for some info i have about forming the club
start up costs are $80 for an incorperated association and $449-$580 (can't remember for shore) for cams affiliation.
Cams affiliation is essential for public liability insurance. it comes as part of the cams affiliation. otherwise you have to go elsewhere and that will cost way to much.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1325
Skyzer,
Where are we up to with this? Do we just need to put our hands up and say yes I want to be a part of a club and we can get this going or are we still working out the kinks. By the looks of it all we need is a few ppl to put a hand up and we can get it happening.
Lets do it instead of talking about it.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1327
Skyzer,
Lets do it instead of talking about it.[/quote:2235aa1625]
basically yes, there are afew things to be ironed out such as the constitution. due we want to be CAMS affiliated (this i would recomend)?
also do we a national body or state ones linked together. still waiting to here back form cams on wheather we can have seperate stae chapeter (ie independant entites) covered under the one CAMS license.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1329
I don't know a great deal about running a club (legal wise) but in my opinion, the ideal situation would be to have one national body, with a constitution which all members would fall under. I don't know how much harder it would be to do this as opposed to seperate state clubs, but surely this would cut down on costs as every member would chip in as opposed to finding the CAMS fees for each club (If this is the case). It would also help get some sort of conformity happening between the states.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1330
heres the reply i got from CAMS about national cover or single states
[b:b837d853ef]"Hi Troy
generally clubs affiliate in the state they are based - tends to work that
way best as then you can take out event permits for events and we know that you are a paid up club within WA
regards Sandra"[/b:b837d853ef]
Looks like CAMS prefers seperate licenses for each state not just one national body. But it doesn;t say we can't try, all depends on member base and number etc. in WA that would lead to about $60 membership fees as only about 10 ppl are interested, 2nd year would reduce as there are no incorperation fees.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1332
    • Yes, but no. You need to keep the mating surfaces bare (ie the flat faces where the caliper and upright pads touch the dogbone) and also the internal threads will remain bare (unless there are no internal threads - do they use nuts on all the bolts?). So you can slow down obvious external corrosion, but not all of it. Anodising would be required to provide decent protection to the alloy, but I'm not actually sure if you should anodise something that is all about the strength. Anodising does reduce strength significantly. Like, up to 50% on some alloys for high thickness coating.
    • Thanks   does painting on aluminium work or stop them from corroding?
    • 'Sgot nothing to do with them being Japanese. The climate in the north of Japan has similarities to the UK - the cars are made in the knowledge that they have snow and salt, and they rot there. Cars made in the US rot like buggery in the US. British cars have always rotted regardless of the weather. They will rot indoors in a climate controlled bubble! The brackets are not unsafe yet, but they will get that way. They may well corrode where the bolt threads are in contact and the bolts could just jump out without warning.
    • So unsafe would you say now?   little bit of has come off, guess road salt is a nightmare for Japanese car. Mx5 here have a well known issue or rotting
    • Dissimilar metal corrosion. Aluminium is less noble than steel/iron, and will corrode preferentially when in contact with it and a conductive solution (ie, wet road salt). Tends to suggest that those brackets should be made in steel for a shitty climate like the UK.
