  • Replies 70
Sqizz
I actually did tape it last night, but not for me - its for a friend (hahhahahh).
All the chicks are HO, except Shannon the areobix instructor. Shes a hotty. Watched her last night in the shower shaving her guttered eewok...
DAM HOTTY
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1319
hmmm nice hi jacking guys.
check out the other thread here for some info i have about forming the club
start up costs are $80 for an incorperated association and $449-$580 (can't remember for shore) for cams affiliation.
Cams affiliation is essential for public liability insurance. it comes as part of the cams affiliation. otherwise you have to go elsewhere and that will cost way to much.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1325
Skyzer,
Where are we up to with this? Do we just need to put our hands up and say yes I want to be a part of a club and we can get this going or are we still working out the kinks. By the looks of it all we need is a few ppl to put a hand up and we can get it happening.
Lets do it instead of talking about it.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1327
Skyzer,
Lets do it instead of talking about it.[/quote:2235aa1625]
basically yes, there are afew things to be ironed out such as the constitution. due we want to be CAMS affiliated (this i would recomend)?
also do we a national body or state ones linked together. still waiting to here back form cams on wheather we can have seperate stae chapeter (ie independant entites) covered under the one CAMS license.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1329
I don't know a great deal about running a club (legal wise) but in my opinion, the ideal situation would be to have one national body, with a constitution which all members would fall under. I don't know how much harder it would be to do this as opposed to seperate state clubs, but surely this would cut down on costs as every member would chip in as opposed to finding the CAMS fees for each club (If this is the case). It would also help get some sort of conformity happening between the states.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1330
heres the reply i got from CAMS about national cover or single states
[b:b837d853ef]"Hi Troy
generally clubs affiliate in the state they are based - tends to work that
way best as then you can take out event permits for events and we know that you are a paid up club within WA
regards Sandra"[/b:b837d853ef]
Looks like CAMS prefers seperate licenses for each state not just one national body. But it doesn;t say we can't try, all depends on member base and number etc. in WA that would lead to about $60 membership fees as only about 10 ppl are interested, 2nd year would reduce as there are no incorperation fees.
https://www.sau.com.au/forums/topic/54-australian-sdu/page/3/#findComment-1332
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
