well my buisness idea has fallen through so now that ive got some cash lying around its time to buy a car and your opinion would help. im looking for AWD turbo and i dont like EVO's.
so here are my options.
1. WRX
2. R32 GTR
3. or wait till summer is over and the good driving times are over and buy a r33 GTR june or july next year?
my real fear is DEPRECIATION (think i spelt it wrong) but yes i hate that word and i relise that somthing is only worth what some one is willing to pay for it.
from the 3 i have noted, i feel that the R32 has done most of its depriciating and realisticly wont fall bellow the 18 or 20 mark in 2 to 3 years. or am i wrong?
any comments would be greatly appreciated.
https://www.sau.com.au/forums/topic/54006-what-would-you-do/
if depreciation scares you then it's time to buy a $500 commodore and accept it.
Car's are not a good investment and you buy them to drive and not make money on.
BTW, the R32 GTR are not likely to depreciate any time soon with the 15 year old import rule going.
WRX are quick in the hands of any driver. Having own one before, they're very forgiving if you make a mistake. Boring if you ask me cause it understeers.
GTR however, will punish you for mistreating it. Drive it right and it's more fun.
You never will know about depreciation. It could drop below those marks.
If you want, you can have mine for $25k. 1993 R32 GTR. :)
all cars depreciate... it just depends on the degree of depreciation. Your right, a car is only worth what someone is willing to pay for it and cars are no exception. They are subject to the normal forces of supply and demand.
Go the R32 GTR... it will depreciate over the next few years but nowhere near the amount for the R33 GTR, mainly due to the discrepancies with the importing laws and DOTARS
great answer...
i know someone with a $300 VK if your interested .. it won`t depreciate much from there
yeah might look in to the commodore more a VB or somthing like that lol
well thanx alot guys i think the GTR is the best way to go i used to have a R33 GTST and i loved that so i might need just to sacrifice the age difference and settle for the power and control. thanx again.
Get the 32 GT-R and with the left over money spend it on re-conditioning it that way its reliable.
Like everyones said, a car is just for driving, not an investment. But in terms of rationability the 32 would be the go (its so old that its not going to depreciate at the same rate as that of the WRX or R33 GT-R. Any car you have you are going to lose money on. Except for antique cars but thats a different league altogether.
Go the 32 GT-R
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
