NOW LOCATED IN SYDNEY
Ok selling my 1993 NISSAN SKYLINE ECR33 GTS-T which is standard except for the rims and tyres.
Price: $19,500 or near offer
Kilometres: 55,000km
Colour: Gunmetal Grey
Transmission: 5 speed Manual
Rego Expires: Will come with 12 months NSW rego
Wheels: 18" Advan Model 5s with Falken 265/35 and 235/40 tyres
Autowatch Alarm and Immobiliser with remote central locking
Apexi Turbo Timer Series 2 spoiler
The car is in very good condition and has 18months left on an ASWN deluxe warranty. Imported the car in June 2003 with 41000km on the clock and had it serviced every 5000km. Replaced water pump and radiator hoses to be on the safe side.
Engine bay is in very good condition and havent had a problem.
Pics can be viewed at carsales.com on the following link:
http://www.carsales.com.au/pls/carsales/!c...rch_distance=25
Contact me through the forum or on 0422 103 239.
https://www.sau.com.au/forums/topic/54031-for-sale-1993-r33-gts-t-sydney/
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
    • Hey all, my 2004 Nissan Skyline 350GT overheated the other day with coolant boiling and leaking out of the coolant reservoir when I was parking. So today, I started it up again just to see if it was a thermostat/head gasket issue. After about 20 mins of running, temps were normal again, no coolant was leaking out and the upper reservoir hose was warm but my engine suddenly cut off. I checked the oil dipstick and cap when it was running and there was no white foamy residue and the exhaust did not have white smoke. I tried starting up the car again but it would only crank, similar to when I had a camshaft sensor issue just that now there’s no check engine light on the dash. Any ideas? Unfortunately I don’t have an OBD2 that can read the Nissan's programme.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
