I have been told but dont know if it is true that the hks shockies are filled with nitrogen gas instead of air (BD4'S) and that i shouldn't let it out...I run on hks hyper adj's.But they are supposed to be filled with the same stuff.since then the shockies have undergone a full rebuild at www.shockreco.com.au in queensland.They will re-calibrate the damper to your specs i.e.softer.Very cheap i thought too @ $143 a shock.
Compnerd, Hipermax II are damper adjustables thus just adjust them around 7-10 or (clockwise +5 to +8 from the middle setting) will give you a softer ride.
As for the valve, I know what your talking about. But I know enough not to go fiddling with it if I don't know what it does.
All gas pressure shock absorbers use nitrogen to help stop foaming in the oil, it squeezes out the air bubbles.. Why? Because air bubbles are bad for damping, the valves need pure oil to work properly, air mixed in just slips straight past the valves. Hence no dampening.
For $143 per shock I can almost buy a brand new Bilstein, doesn't seem like good value to me. In addition I have no car for a week while the shock is away getting rebuilt. Plus, even after the rebuild, I still end up with a simplistically valved, twin tube, Japanese shock absorber that isn't designed for the rough stuff we have to put up with.
My 20 cents worth:cheers:
thanks sydney kid "I REWCON YOUR 20 CENTS WORTH "IS EXTREMELY GOOD VALUE!THANK YOU EVERYONE,IS THERE ANY WAY OF GETTING THESE THINGS UP TO AUSTRALIAS SHITTY ROAD SPECS,I ALSO HAVE ACCESS TO NITROGEN ,DOES ANYONE KNOW HOW MUC :Pimp: H THEY SHOULD HAVE?
CHEERS AND THANX
Guest two.06l
I Have An R33 Gtr With Hks Hypermax Coilovers,they Are Extremely Hard,they Also Have An Air Valve At The Bottom Of The Rears,what Is This For,any Help In Setting These Up Is Much Appreciated :)
we found that by running ours at a sensible ride height and setting the shock three clicks from its softest setting was the best to make the shock actually do its job and WORK.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
