I have been told but dont know if it is true that the hks shockies are filled with nitrogen gas instead of air (BD4'S) and that i shouldn't let it out...I run on hks hyper adj's.But they are supposed to be filled with the same stuff.since then the shockies have undergone a full rebuild at www.shockreco.com.au in queensland.They will re-calibrate the damper to your specs i.e.softer.Very cheap i thought too @ $143 a shock.
Compnerd, Hipermax II are damper adjustables thus just adjust them around 7-10 or (clockwise +5 to +8 from the middle setting) will give you a softer ride.
As for the valve, I know what your talking about. But I know enough not to go fiddling with it if I don't know what it does.
All gas pressure shock absorbers use nitrogen to help stop foaming in the oil, it squeezes out the air bubbles.. Why? Because air bubbles are bad for damping, the valves need pure oil to work properly, air mixed in just slips straight past the valves. Hence no dampening.
For $143 per shock I can almost buy a brand new Bilstein, doesn't seem like good value to me. In addition I have no car for a week while the shock is away getting rebuilt. Plus, even after the rebuild, I still end up with a simplistically valved, twin tube, Japanese shock absorber that isn't designed for the rough stuff we have to put up with.
My 20 cents worth:cheers:
thanks sydney kid "I REWCON YOUR 20 CENTS WORTH "IS EXTREMELY GOOD VALUE!THANK YOU EVERYONE,IS THERE ANY WAY OF GETTING THESE THINGS UP TO AUSTRALIAS SHITTY ROAD SPECS,I ALSO HAVE ACCESS TO NITROGEN ,DOES ANYONE KNOW HOW MUC :Pimp: H THEY SHOULD HAVE?
CHEERS AND THANX
Guest two.06l
I Have An R33 Gtr With Hks Hypermax Coilovers,they Are Extremely Hard,they Also Have An Air Valve At The Bottom Of The Rears,what Is This For,any Help In Setting These Up Is Much Appreciated :)
we found that by running ours at a sensible ride height and setting the shock three clicks from its softest setting was the best to make the shock actually do its job and WORK.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
