Guest Stupid!
well i guess i wont be on this site nemore i loved reading what u guys said about your skylines and i esp loved owning one but i have jsut been told by my parents that my dad is buying the new sl 65 amg model so that means he no longer needs his 2003 model m3 which is now mine and no matter how much i love my line i still love the m3 better so am now selling my skyline which i only had for about 10 weeks.
btw thanks for all the help from people i leard a lot about skyline and cars in general neweays cya all laterz.
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/
Yep... at least it is still a straight-6. You will have a blast.
Hopefully you will get the SL65 as a hand-me-down when he replaces that... :D
If you are after a BMW forum try http://www.dtmpower.net/forum/forumdisplay.php?f=37
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/#findComment-1061280
Geez, i feel so sorry for you, having to sell your skyline because you have to drive a crappy old 2003 model M3. I'm just glad i don't have to put up with that sort of stuff. My deepest sympathies for you.
But seriously. Good luck to ya, make sure you drive it how it was meant to be driven :wave:
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/#findComment-1061733
duuuudeee!!! i hate you so much right nyah!! :D
Is she SMG II or 6 speed? Colour? Pics? 19" rims??? :D
That would have to be THE coolest hand-me-down ever. My current car is a hand-me-down too! but it's a '91 Nissan Pulsar hatch, 1.6ltr :( - But i'm stepping up soon as well!
If you're in Melb, make sure you bring her out on a cruise :D
enjoy one of the best engines ever to have graced a performance car :D
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/#findComment-1061840
Clearly that learning didn't include classes on how to spell though.. but you did learn how to type in an internet forum over the holidays and it was so much fun .. and I could tell all my friends!!!
hey since i am buying my first skylie in janurary r 33 gtst 96 model most likely i was just wondering how fast a standard skylie should run 0 to 100km/h in? how many seconds also i c a lot of people...
mate, you are so full of crap it hurts.. I guess the dream ended before it even begun huh?
Where is this car? You're 12 years old aren't you?
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/#findComment-1061853
meh lying or not the m3 is not such a great car, we've competed against them a couple of times and kicked their arses with a 33 gtst and teh 31 gtsr.
plus they have the tinniest sounding exhaust I have ever heard.
plus, there's a recall on them to rebuild the engine :D BMW quality eh? NSW Members only: http://www.skylinesaustralia.com/forums/sh...ead.php?t=52302
or...
"All E46 M3's are now subject to a big end bearing re-call. This entails removing the sump and installing new bearings as well as new bolts and sump gasket. The really funny bit is one size bearing fits all regardless of kilometres travelled. I'm not real sure if this includes the poor bastards that have already had engine changes but I'll bet they are. Glad I didn't pay $130,000.00 plus for such a piece of crap." posted by someone who knows :D
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/#findComment-1062081
i must agree with you duncan , they are crap . i have seen several put conrods through the side of the block as well as the bearing issue , i guess thats the reason they bust conrods ( they keep drining them with spun big end bearings .
you would expect better when you pay $150k + for a car .
as for just removing the sump and replacing the big end bearings , well what can you say , if the crank is 100% unmarked it maybe ok but in most cases you would have to remove the crank , regrind and use undersise bearings . thats what i would do if it was my car , at the very least pull the crank out , check clearances and if everything is ok then at least linish it .
or...
https://www.sau.com.au/forums/topic/54143-cat-beleive-this/#findComment-1062294
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
