http://www.directebook.net/walbro.jpg
Walbro 255lph High Pressure Fuel Pumps
Model GSS-341 with 400-766 fitting kit
supports 500hp
Pump and kit comes with everything needed to plug and play
*UPDATE* - Spoke to the supplier and he said he can do each fuel pump for:
- $170.00 each (5-10)
- $160.00 each (10+)
Also for all Melbourne buyers, installation is available for $35.00 (drive-in, drive-out price) from EX-MOD Performance located in the SE suburbs.
Once I get a decent number I will go ahead and confirm a cut-off date.
thanks
*This group-buy will end on the 12/11/2004, so please only if you are 100% please post.
POSTAGE = $10 anywhere in Australia.
Thanks*
So far:
- Abo Rob
- predator
- Cameron (x2)
- Jay95R33
- Nexus9
- gtst25
- Jolinator
- knore
- Silver Gts-t
- Sal (x2)
- Nightcrawler
*LATEST*
For all above please can you please PM me for my bank details if still wanted to go ahead. Last day is Friday so last day for payments will be then. Please also indicate if extra for post will be included.
Thanks.
https://www.sau.com.au/forums/topic/54154-walbro-255lph-model-gss-341/
  • Replies 50
it wont run rich as such. Your ECU controls the flow. When you boost your car, the ECU will send more fuel to come in to avoid running lean.
The standard fuel pump can only release a certain amount of fuel so what this fuel pump does it increase the flow, in the end increasing performance and reducing the chance of engine damage and pinging.
any ideas if this would be a higher pressure / flow than an R32 GTR pump? i need another pump for the 240k, but not sure which to use as the main pump from the surge tank (as oppose to the pre pump from the tank)
Guys,
I might be out of line here but rather than asking a bunch of comparitive detailed questions of the guy organising the group buy, how about we all do our own research? You need to convince yourself that this is what you want. He is not selling it to you, he's getting it for you.
It's not like this pump is an unknown quantity and even on this very forum you will probably find all that you need. Perhaps as interested people do the searches they might like to post links to any good info that they find.
It's just that I've seen a smiliar sort of thing in a couple of group buys now and the person organising it can very easily get the shits with it all and decide it too hard then we all lose out.
Let's all help each other here.
:D
ok, to give some light on some of the questions ...
I bought one of these, and fitted it a couple of weeks ago, paid $200 for it shipped ... gah ..
anyway, i did do a thread on the forums about it but below is a list of things i found...
1. removal of the old pump is easy, the hardest part of removing the black screw ring around the tank access pannel.
2. everything just fits with this walbro ! the ONLY thing you have to modify is the electrical connections to plug in the new pump, but you get everything you need to do this anyway ... all you need for the mod is a pair of pliars.
3. you can easily use the existing mounting bracket, the new pump even comes with a rubber gromet / brush type thing that fits into the bottom of the bracket, and lets the new pump fit perfectly. you don't need the extra fuel tube that comes with the pump, or the clamps.
4. the new pump is a LOT thinner than the stocker, so does not sit flush against the bracket along the length of the pump, its not a prob as its held in pretty well on the top and bottom, i just decided to whack a couple of zip ties around it anyway ..
5. the sock filter from the stock pump fits directly onto the new pump, you don't need the filter that comes with the new pump.
6. it does not seem to run any richer than before with the new pump, the 255lph is only what it CAN deliver, not what it does deliver all the time ... your injectors, and pressure reg will control how much fuel the engine actually gets ...
and thats all i have to say about that ...
hope some of your questions may have been answered ...
cheers
Baz
Guys,
:D
Actually make that 5 pumps for me in total.
A couple of guys i know are after one so saves them making a new account etc.
:D
Cam
thanks !
just one more note, i put a desk fan about 8' behind me on full power, just so that fumes escaping from the tank were not concentrated all in one place, the fan would disperse the fumes, and so should be less of an explosion risk ...
petrol fumes ignite pretty easily !
Like Mr Bob says.. there is plenty of info on thse in the forced induction section.. they are a nice fit for an R33 or R32.. and good for up to around 250rwkw, maybe a bit more.
When I analysed them apples for apples to an Bosch 910( using same pressure) they are pretty much the same as this.
So they are a great upgrade ! and easy to fit..1 hr if you don't even know what you are doing. Even as a safety precaution, as fuel pumps get old they start to flow less than optimally - at worst a dead pump under load can mean a dead engine.
Usual price on these is regularly $200, so if he is able to get them for $160 for 10 that is a good price..
AND (still interested) :mad:
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
