Installed my REV.EL dials tonight at my brothers house (coz he has a garage with lights)
All seemed to go well until i tried to drive home. About a minute down the road the hicas light comes on and the steering becomes very heavy.
We've got no idea wtf the problem is! The only thing we can think of is that we've unplugged something behind the centre console and not plugged it back in.
The only thing we can see is a plug similar to the hazard light and dimister switch plugs that seems to have no where to go.
Does anyone know what the prob could be?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/
Hicas Diagnostics returned a series of short flashes. pause, 2 long flashes. 1 short, pause. repeat. Which if am reading it right means
error code 21 - Speed sensor not hooked up.
Well i've taken the consol apart and had a look nothing seems to be amiss. The speedo still reads accuratly, and my turbo timer which is also hooked up to the consol can read the speed. So I have no idea whats wrong here? does anyone have any ideas?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/#findComment-1061928
hey rory um just a though u checked the fluid level float I had a HR31 that the float level use to get stuck down & make the light come on just as though as for the hub/wheel speed sensor did u jack the car up or any thing?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/#findComment-1061936
Never mind, I figured it all out...problem solved. Turned out the washer on my Turbo Timer tap into the consol did not have a good connection and was screwing everything up. Anyways now that error code is logged in the HICAS Diagnostics, so it will report that code everytime I run a diagnostics... So how do I reset it? do I have reset the ECU?
https://www.sau.com.au/forums/topic/54181-help-with-hicas/#findComment-1062597
