345 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hmmm interesting... That'll definitely be the go for the R32 when I find one... Seeing that the only road time it'll be seeing is to and from the track and the odd cruise, comprehensive insurance is overkill.
  • Replies 106
shannons insure my r32 gtr, its on the super light use policy.... not more than 4000ks a year. only 800 notes though.
if i do more than 4000ks, it jumps up $300 to 8000ks. then a few more hundred if more than 8000 to unlimited ks.
perfect for me.
Im with Just cars, in Melbourne, R32 gtst, 22yo, lightly modded, rating 2 and i pay $1200 a year for an agreed value of $16000.
I am so glad i dont live in Sydney.
In Vic we have CTP like in NSW but do dont have a choice who you go with, its all included in the price of rego. (thats why rego is like $550 in here).
Guest Mashrock
who would be a good insurer to go with.
mind you i'm mainly going to be usiing the car for track racing and a bit of weekend driving.
and i also know that many insurance will not cover for the track..
i is also got a bucket load of mods,
i sent a quote off to just cars.
also i am 22..
i'd probably want the car insured for say 30k
32 gtr
Wouldnt drive my cars unless they were covered by full comp, the GTR cost me 3200PA and i was 18, the GTS with the V8 now costs me 1600PA, no i cant afford to insure both thats y only one is on the road at one time and while the other one is off the road it is chained to the garage floor until one of them sells.
Thats with just cars by the way, they said under normal circumstances they would not have touched an 18yo with a 33 vspec but because i had the gts since i was 16 and had not made a claim with them they would insure me.
I'm not sure if just cars will do an agreed value on older cars.  I really had to argue with them for my 97 model line.  From my experiences (fairly limited) just cars have been the best and the cheapest.
They did it on my 92 gtst... Famous couldnt match just cars in my case
  • 4 weeks later...
im 23yrs old and just car was about $1100 including all mods, but then again i have a 4-door r34 gtt which is classed as a family car, my previous NA JZA80 insurance was $1300. All rating one and comprehensive. My brother is a rating 3 or 4 and hes s15 costs him about $2000 from 'young and cool'.
Fully comp..... A car worth more than 10k or so then fully comp....
My 4x4 us a little shitty and worth about 20 bucks so i just got third party fire and theft on it as its $150 bucks a year. Never know might come back to the car after fishing and it may not be there so $5k coverage for 150bucks with a 600dollar excess on it. Thats a bargin to me. The skyline on the other hand is 1400 bucks with a 2400 excess but she is insured for 30k. I understand the high risk, i do drive very safe. But im more scared of it being stolen than anything else.
So i answered fully comp as the line is my daily car.
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
