waste of money for the motec, stroked motor, forged internals, custom plenum, twin bosch pumps and surge tank, you dont need all that stufff to run 10s,
all you would need is injectors, 044 fuel pump, cams, bigger turbo(s) power fc, cooler, standard box is fine, and some good slicks you should get into the 10s with a few passes, then after you get into the 10s then you have to spend big bucks to get back on the track.
I know, I think my mind is set on 9's :/ But can just run it on low boost for easy 10's ;)
I agree with BU5TER, and that was the underlying point I was making. One time wonder or long time contender?
Butler, could you please let me know any info you have regarding the Apexi cranks/stroker kits as I can't seem to find any info on them.
TIA.
Charlie
You need 450rwhp and a good clutch and reasonable tyres.
Jade fishers R33 has Arias pistons ( all origional parts went back in inc the old bearings),smallish ITS plain bearing turbo and Wolf plugin ECU and ran 11.1 all last season with not one problem.
Single throttle kit going on now and i think 10s will be easy this season.
2530's you aint running pump fuel for 400kw
anything is possible if your not running  PULP
Straight Av gas.., around 100 octane. And that is not suppose to be the best. Have to when the best fuel here is 96.. and it's no good.
Be interesting to see what it would go like with some C16.
It's a testament for the GTR engine though, and it has done more than a few 10's runs without failure... I would call that consistent.
Not only that is was a daily driven street car.. damn I miss her :/
A note on the Trust 6 Speed box.. we removed it from the GTR running a T88 to repair it, he couldn't run good times with it.
With a stock box, he didn't have a problem running 10's. ;)
I hated driving the dog box on the street, it's just a major pain in the ass. They don't like to change at low RPM.
I'm struggling to get my 32R into the 11's let alone 10's and power so far is 370rwhp on paper and going off other cars should be into the 11's easy but it's not . Best run so far is 12.1@114mph with a 1.760ft , it comes down alot to your tuning as it's not alway outright horsepower that gets low ET's something that I've realised and am looking to correct.
Hi 7heavn
Unfortunately the best times for a GTR are achieved with a "brutal" launch (this makes me cringe every time I do this to my R). Your 1.7 60' time suggests that you are probably not bogging down on launch (your at 6 to 7k before side stepping the clutch, right?).
You are right about the tuning - if you have adjustable cam gears and have dialed in for max hp (at the expense of mid range tourque), you may be dropping off below the max torque in between gear changes. A dyno graph showing power and torque vs revs would help.
I was previously rattling off 12.5s with only 320 rwhp (std terbs) fairly consistently with 1.9 60' times. It sounds like more practice (and maybe a little cam timing adjustment) will see you crack 11s fairly soon. Remember to pre-load the drivetrain using the handbrake and take that 2nd to 3rd change E-A-S-Y.
Good luck.
id think bout changing diff gear sets also, to maybe 4.3 like the gts4 has
my 32 gtst wasnt the same with 4.11's the 4.3's bring the 26 to life over the quarter.
my 26 has 272 cams NO internals and a big single turbo its run best now of 11.1 @ 126mph im sure as is 10's are possible.
My wifes GTR ran 12.0 @ 119.34mph with me being very soft on her car, as you can see 119.34mph means strong 11s driven hard.Her car had a cat back, gmax clutch and a Wolf plugin using the stock AFMs but nothing else. 338rwhp.
We have removed the AFMs now and and ive been told by the boss to take it to the plex again and not to come home with out some strong 11s so ill see what it can really run.
Hi 7heavn
Good luck.
Hey
Yep 6500rpm sidestep the reason I mentioned the 60ft is just to clarify that not much is being lost at the bottem of the track you see 370rwhp and 114mph through the traps doesn't make sense . My mph should be something closer to steve-sst's wife's car . Only other thing I can think of other then tuning is mine is a vspec is the gearing differen't?.
    • I dunno man, that VX S with 200,000 k's is still hanging out for 1.5 I reckon the R34 is the better buy, personally.
    • Dang, doesn't even include on roads.
    • Only in a market where OBD was a thing. The rest of the world was quite happy to let the US EPA only affect US cars for quite a while. The* problem with datalogs is that unless you are very familiar with what every trace should look like, on their own and as an ensemble, you can and will see weird shit that can and will lead you astray, not realising that what you are seeing is the normal consequence of various transient inputs. *Really, "a" problem, as there are of course many other problems too. Look, these cars are so bloody simple that if it is missing or stumbling, the obvious thing is to break out the old mental diagnostic list and just go do all the things that you know you should. After proving that the plugs are clean and sound, ditto the coil stalks, coils, loom connectors, etc, and then making sure that there is fuel pressure at about the right numbers (while driving!, not while sitting in the garage free blipping it), then maybe you go looking at AFM voltages, manually testing the igniter, putting a scope on the CAS, etc. Then you're into pulling the injectors for a spray pattern look-see and perhaps a clean, squirting carby cleaner around the inlet manifold looking for leaks, and all the more annoying and esoteric, but still common as muck faults that these things have. I wouldn't ever bother looking at the trims, as they are usually bullshit on these old clunkers anyway.
    • Jousting sticks! Tell 'im he's dreamin!
    • GTR owners are wankers - 2025
