waste of money for the motec, stroked motor, forged internals, custom plenum, twin bosch pumps and surge tank, you dont need all that stufff to run 10s,
all you would need is injectors, 044 fuel pump, cams, bigger turbo(s) power fc, cooler, standard box is fine, and some good slicks you should get into the 10s with a few passes, then after you get into the 10s then you have to spend big bucks to get back on the track.
I know, I think my mind is set on 9's :/ But can just run it on low boost for easy 10's ;)
I agree with BU5TER, and that was the underlying point I was making. One time wonder or long time contender?
Butler, could you please let me know any info you have regarding the Apexi cranks/stroker kits as I can't seem to find any info on them.
TIA.
Charlie
You need 450rwhp and a good clutch and reasonable tyres.
Jade fishers R33 has Arias pistons ( all origional parts went back in inc the old bearings),smallish ITS plain bearing turbo and Wolf plugin ECU and ran 11.1 all last season with not one problem.
Single throttle kit going on now and i think 10s will be easy this season.
2530's you aint running pump fuel for 400kw
anything is possible if your not running  PULP
Straight Av gas.., around 100 octane. And that is not suppose to be the best. Have to when the best fuel here is 96.. and it's no good.
Be interesting to see what it would go like with some C16.
It's a testament for the GTR engine though, and it has done more than a few 10's runs without failure... I would call that consistent.
Not only that is was a daily driven street car.. damn I miss her :/
A note on the Trust 6 Speed box.. we removed it from the GTR running a T88 to repair it, he couldn't run good times with it.
With a stock box, he didn't have a problem running 10's. ;)
I hated driving the dog box on the street, it's just a major pain in the ass. They don't like to change at low RPM.
I'm struggling to get my 32R into the 11's let alone 10's and power so far is 370rwhp on paper and going off other cars should be into the 11's easy but it's not . Best run so far is 12.1@114mph with a 1.760ft , it comes down alot to your tuning as it's not alway outright horsepower that gets low ET's something that I've realised and am looking to correct.
Hi 7heavn
Unfortunately the best times for a GTR are achieved with a "brutal" launch (this makes me cringe every time I do this to my R). Your 1.7 60' time suggests that you are probably not bogging down on launch (your at 6 to 7k before side stepping the clutch, right?).
You are right about the tuning - if you have adjustable cam gears and have dialed in for max hp (at the expense of mid range tourque), you may be dropping off below the max torque in between gear changes. A dyno graph showing power and torque vs revs would help.
I was previously rattling off 12.5s with only 320 rwhp (std terbs) fairly consistently with 1.9 60' times. It sounds like more practice (and maybe a little cam timing adjustment) will see you crack 11s fairly soon. Remember to pre-load the drivetrain using the handbrake and take that 2nd to 3rd change E-A-S-Y.
Good luck.
id think bout changing diff gear sets also, to maybe 4.3 like the gts4 has
my 32 gtst wasnt the same with 4.11's the 4.3's bring the 26 to life over the quarter.
my 26 has 272 cams NO internals and a big single turbo its run best now of 11.1 @ 126mph im sure as is 10's are possible.
My wifes GTR ran 12.0 @ 119.34mph with me being very soft on her car, as you can see 119.34mph means strong 11s driven hard.Her car had a cat back, gmax clutch and a Wolf plugin using the stock AFMs but nothing else. 338rwhp.
We have removed the AFMs now and and ive been told by the boss to take it to the plex again and not to come home with out some strong 11s so ill see what it can really run.
Hi 7heavn
Good luck.
Hey
Yep 6500rpm sidestep the reason I mentioned the 60ft is just to clarify that not much is being lost at the bottem of the track you see 370rwhp and 114mph through the traps doesn't make sense . My mph should be something closer to steve-sst's wife's car . Only other thing I can think of other then tuning is mine is a vspec is the gearing differen't?.
    • It doesn't really answer your question...but is the head unit full android or just android auto, are you happy with how quickly it boots and responds, and do you have a link?  If we can identify good Android alternatives it will really help people stuck with Japanese screens. Did it have a separate reverse camera input so you would replace the factory one, or are you just going without now...that would be a pretty big steps back. And finally, do you have a picture of the "wire" that you can't plug in? Most likely it is some sort of aerial that is not too important eg japanese traffic or am radio or something if you haven't noticed a functionality issue
    • haha funny enough I did ask him wtf he had been up to with the electrics....but no answer
    • For a daily just run Akebono ceramic pads. That's what they're optimized for. Obviously don't try to run it on track or anything like that.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
