R33 fitment is IDENTICAL to AU (and BA I think) Falcon, and no doubt plenty of others. 5x114.3, +20 offset iirc. Ford steelies are common on the back of Nissans at the drags, and R33 wheels are common fitment on R32s, same goes for 34 wheels on 33s and 180SXs etc. They will bolt up, but I'd be checking guard clearances on GTSt's on the front. It might be OK, but I'd be checking it anyway ;)
Are they your new mags in the background? :/
The Guy I Brought Them Off Had Them On A 32 Gtr He Said You Will Have To Change The Back Tyres 255/35 To The Same Size As The Front 235/40 As The Torque Settings On The Car Will Be All Over The Shop, If You Have The Same Tyres All Around You Possibly Could Get Away Using Them On A Gtr, But You Really Have To Use Same Width Wheels On A 4wd Car...
YEAH MATE 13INCH HUBCAPS..
you dont have to really use all the same width all the way around, cause the car isnt constant 4wd, its 2wd most of your driving even while your franging it, its only why your rear slips that the front cut in,so it doesnt make a differce I drive on 285 rear and 245 front with now problems.
up to you wreckedhead i had a thread up a regarding this and i was told if i keep the wheels on i will end up stuffing the tranfer case clutch...
never heard that befor but anything is possible. all my mates are mechanics and some specialise in gearboxs, i can give you a number so you can find out personally if it will stuff the box/clutch
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
    • So you had a car that by all accounts drove well and survived track days, and that was looking great after months of being stuck at a paint shop. Some might call that a finished project. But you decided this is not quite right. So now the car does not run anymore. And the engine doesn't fit anymore. And the body parts don't match anymore. But, this is progress somehow. Greg, I think your subconscious does not like you and does not want you to drive this car. (I know I know, this whole escalation was not intended, but man, what a rollercoaster)
    • Yeah, but the narrowband is truly narrowband. So you take it out of the linear zone and it is effectively nonsense. And that linear zone is so literally narrow, that nonsense is not very far away. Unless they are flicking back and forth across the stoich point, for real, under actual control, they can't be trusted for anything except entertainment value.
