Mine has made 200rwkw (197,200,200 on three seperate dyno's) on standard injectors. I must admit though, the tune was quite lean. It has got a Bosch 040 in tank pump, and no form of fuel pressure adjustment apart from what the pump delivers. Dunno how, as your calculations seem to point to them being un-able to make that sort of power?
P.S -thats my qoute about the 18psi :D
Chris
@ 100% duty i.e. not giving the injectors enough time to open and close and given you only have less than 40kw loss...yes this is possible!
But highly not recommended 90% is still OK...but tuners will do it at 60-70% duty, over here anyway.
My bet is that isn't far from the truth, its the most feasable and lateral answer to the question :D If that was the case, there is bound to be a few more around
Most people's injectors are covered with a bit of filth and are hard see without removing them, I will keep a eye out for other RB20 injectors and see if I can find another!
If they were CA or GTR injectors, there would be a ballast resistor attached to the loom somewhere, so I stand by what I reckon - ran out of red colouring! :)
Chris
@ 100% duty i.e. not giving the injectors enough time to open and close and give you only have less than 40kw loss...yes this is possible!
I am pretty sure they where near on 100%, as soon as the fuel filter became the slightest bit of dirty, it would suffer light detonation - new fuel filter and some injector cleaner in the tank and all would be good
The car would backfire and flame alot when I came of the throttle, suggesting to me the injectors where working 100% of the time and there would be a little bit of fuel still entering the cylinders after I had lifted of the throttle
hopefully the new injectors will need no more than 60% to make 200odd rwkw
Chris
What injectors did you go Chris?
Let me know how the fuel consumption goes with them. :D
I went 440cc GTR in the end, and wired in the resistor pack etc, I figured it would be plenty for my RB20
So far with the PFC closed loop function, fuel economy is around 10 litres per 100km, about a litre per 100 better than with the re-programmed ECU :D The PFC closed loop function is first class, providing it is setup right
In the injector correction section (cant remember exactly) there is a correction and lag setup, if you work out the percentage differance from stock and enter this value in - for me it was 58.5% and the injector lag time, in my case -.12ms, it runs better than ever before and delivers quite good economy
The injector lag/cc table for standard nissan stuff can be found here - http://www.ap-engineering.co.jp/el/inj_top.htm
Its being tuned shortly for more boost etc, but hopefully the economy will remain similar providing I dont use the loud pedal too often :)
  • 5 weeks later...
The most common upgrade for RB20's are the 444 cc GTR injectors, with the GTR resistor pack to match the impedance, they are a good choice at realtively low cost as there are many around.
:P
In practice, what is the maximum power achieved with 444cc GTR injectors? I am searching through the forums right now, but may as well ask at the same time.
Reason being, I am going shopping for some parts on the weekend and there doesnt seem to be much price difference between R34 GTR injectors or aftermarket 550cc injectors here in Japan, so I could go either way. I do not want excessively large injectors though and my realistic power goal is 250rwkw from my RB30DET.
Opinions on this choice with fuel economy and idle in mind?
EDIT: Found it ~270rwkw. Opinions still welcome.
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
