Thanks once I work out the controller will check. also noticed that it isn't monitoring the air temp. I know that they fitted a new dump and high flow cat and when i got under and had a look didn't see the wire that was connected to the old cat was missing.
I wish they would make these intructions in english :-)
Before I start playing with the PFC does this sound right to turn off the boost kit:
etc mode
Function Select
Boost Cntl kit
Edit:
Yup that was it engine light is gone .. thanks for the help!!
hey dude
The rb25det does not have a air temp sensor that i know of. I wonder if you can install one and get it to work with the rb25det computer?
someone help !!! would be nice to have air temp sensor
Nope - the reason that it appears on the HC menu is to do with the fact that the RB26 PFC (which does use input from an air temp. sensor) uses the same HC model as the RB25 PFC (which doesn't have such an input). The menus shown are largely dependent on the HC model, and not the PFC model.
    • Build an 800hp motor. Make it as bullet proof as you want, you WILL still break things. Like, the rest of the car. Heck, even as a dead stock car, things will still break, but the more power, the more everything else will let go easier. From gearbox gear sets, to extra stress on the chassis/mounts, more stress on diff, axles, tailshaft, even the suspension mounts. Check out the motorsport build that last year went to a Bosch motor sport ABS setup, and now can brake so damn hard it's twisting mounts for suspension/subframe etc. Now if the brakes can do it, imagine what happens with super grippy tyres and 800hp in a low gear...   Shit, I'm presently out fixing the girlfriends daily driver that rarely sees past 3,000rpm and is used to cart the dogs around in. Everything WILL break. If you don't want it to break, don't drive it. And then laugh, as it will still break without even being driven!
    • ECUMaster is an Australian company from memory, been around a while, and seem to actually play really well on more unique engine setups. Seems to be more of them being used in the states, and they seem to support more cylinders than most others.   My opinion on stock ECU/Nistune with he AFM, is you can tune around the issue of stalling. It's still a bit of a band-aid, and not the most perfect smoothest setup, but it can make it drive able and not an absolute PITA. But you're still compromising. A vent to atmosphere BOV has the same issue as no BOV with regards to the AFM. Both make the ECU think more air is entering the engine than there really is. And I can't find any hard science/decent evidence that supports the claims all the "you MUST run a BOV of some sort of you'll blow the turbo up". About the only one some people can give of why is "lag between gear shifts", and that is only an issue when your boost source for the waste gate is pre throttle body. I ran my boost source for the TD07S off the inlet manifold. Didn't have weird boost spiking issues, didn't have boost control issues, and on a gear shift the wastegate slammed shut, which meant all exhaust gases would be keeping it going round and round and not waiting for the wastegate to shut again when I stepped off the clutch and back on the loud pedal. It came back on boost in the next gear pretty much instantly.   ECU / tune / BOV choice I think really comes down to a lot more factors than just what you've stated. And personally, especially for daily driving, recirc setup for the BOV, or no BOV. I dislike the really loud BOV when everyone is taking off from the lights etc.
    • Hey guys, as the title reads I would like the buy a S1 GTT OEM lip for my skyline. Located in Australia. Happy to drive to pick it up (interstate I don't mind)
    • All motors are consumables. This thing costs $250,000-500,000 and makes 640hp/430 KW, naturally asipirated. It has a competitive advantage in being more reliable than other cars it competes against. They rate these engines in hours before rebuilds. Are you going to out-engineer half million GT3 car manufacturers in a garage? People really need to be honest with what they are going to do, and remember that 99.9% of the people on the internet are not honest with how they use their car and what it holds up to and how much power it makes and how easy/hard it was. Anyone worrying about the block limit of anything is the kind of person that will be unable to do a single track day, for example, perhaps not even a single session. Build the kind of car you would want to have if you could never tell a single soul about it and nobody would ever know.
    • For anyone who finds this via a search  An s14 alternator connector and Silvia Fusebox/350z headlight connector can be used. Get the non pigtail version of the alternator connector so you can use 12 gauge wire for the pump.    I am using  https://ebay.us/m/ToEEmM And https://conceptzperformance.com/czp-xenonhid-headlight-connector-w-pigtails-8-pin-male-nissan-350z-03-08-z33-or-jdm-fusebox-for-silvia-s14-czp-26060-m-8pin_p_19166.php
