My AVC-R does a few weird things. Mainly in the overboost department. I have set it to run .65bar however at times it spikes up to .75 or .80 bar before dropping to .65.
a. Is this normal??
b. Have I got it hooked up right. I have a vaccume line comming off the "surge tank" which has a t piece. One line goes to the pressure sensor the other goes to the BOV.
the apexi documentation is kinda crap..
I am assuming the Air Filter Pressure Regulator is the BOV right.
https://www.sau.com.au/forums/topic/54271-avcr-question/
Drop the duty cycle down. When the AVC-R thinks the duty cycle is correct (when its not overboosting) it will change from three numbers (e.g 055) to ***. Then just run it in self learning mode for a while to self tune it a bit and it should all be good.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1064511
Whats the T piece for ?
Are you running a external wastegate or stock set-up ?
For stock set up it should go from your intercooler pipe/turbo/serge tank or were ever you have it plumbed into. That goes to [NC] on the avc-r solinoid and [COM] goes to turbo actuator.
Check your F/B control if this is too high you will get spikes. And as other's said adjust your duty cycle to get your boost to what its set at.
Jun
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1064931
This looks like a good thread to put my question into.
I've drawn a graph (using ms paint, please forgive me) of my boost curve on the road.
It doesn't do this on a dyno but it does on the road. It's most pronounced in 2nd gear but does still do it in 3rd.
I have the boost duty set quite high because it struggles to get to the set boost. (0.85 bar) It often peaks at 0.78 or so even though I have it set to 0.85.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065166
T piece is for splitting the vaccume line off the plennum / surge tank. 1 goes to the AVC-R sensor the other goes to the BOV.
I will sus out this F/V control you speak off. Might also try dropping the duty cycle, however since the boost is level after the spike not sure if thats the cause. Its almost like it delays the opening of the waste gate.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065383
a. Is this normal??
In that diagram "Air Filter Pressure Regulator" is acutally 2 things "Air Filter" refers to the small plate shapped thing to the left of the text and it's the air filter that goes in the vacuum line feeding pressure to the pressure sensor (it comes with the kit). "Pressure Regulator" refers to the Fuel Pressure Regulator.
HTH mate :)
Richard
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065389
What is your start duty set to.
This can able you to spike your boost or under spike it. might help level out your graph a little bit.
It's not ramped at all at the moment. I might try easing it off in the lower revs so that it doesn't hit so hard.
Just feels quicker with a hard hit of boost. :)
Ta.
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065440
Ahhhhhhhhhhhhhhhhh!
I got you dude.. yeah. those little clear air filter things!!
BING WAHHHHH
might do some reworking of these vaccume lines.. see if it helps the spike issues..
Yep, that's the ones. Man you got gipped though if they are clear, my trust thingy came with green ones :looney: yeeha!
The re-working might help, but it sounds like it's most likely a tuning/programing problem.
Richard
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1065875
hmm, I don't know of any places in melbs but any place that sells all that kind of nice flashy stuff (avcrs etc) would have 'em. I know in sydney I'd go to somewhere like advan, or UAS, but if none of the local shops have them you could mail order from syd, or Japan for that matter.
Richard
https://www.sau.com.au/forums/topic/54271-avcr-question/#findComment-1066940
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
    • After its dried out Penetrol is you friend to treat rust and seal up those seams
