I am looking at BuyingLT-12 Microtech But want info if anyone has had problems with the unit.......... like fitting or programing! I really don't know much about ecu's but I have done most of the bolt on mods and I now want to tie them in all together and get rid of the flat spot in my boost curve.
Can you use the boost controller with the LT-12 Microtech. I am running a HKS Boost controller (older type ).
Question, Question .........need answers:D
Hi dude, Ive just had one installed. Sweet. No probs at all. I was quite concerned myself, as i heard some bad stuff about micro tech. This has proven to be a bunch of bad hear say. I nearly went a power FC over the micro tech, but with the results i got and the money i saved, im glad i didnt!
What turned my opinions around completely, was when whatsisname took me for a spin in his LT-12 equipped r33.
You can use the micro tech boost controller that comes with the computer -its electric, and uses the factory solenoid. -or you can use your own one. Whatsisname uses an HKS EVC with his LT-12.
I also had the flat spot you mention, actually due to the airflow meter and the stock computer, which is now gone. It now pulls clean and strong to the new 7500rpm redline. (the ECU also removes all your cuts -speed, revs, boost etc...)
Conservatively tuned for reliability stakes (no chance of pinging) it now makes 200kw at the wheels on 12psi, and the usual mods (turbo back exh, filter, NB changed the fuel pump to an 044 bosch)
Tuning and fitting were straight forward also.
cheers.
I should mention that the guys who fitted and tuned mine, at RPM perf. centre, are experienced with micro tech, which is probably why they got it right first time. I cant vouch for ease of tuning if done by a less experienced tuner, but ive heard they are pretty good. Hope this helps!
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
