  Birnie said:
Grab a bleeder valve fro $100 and do that whenever aswell.
My Power FC is currently collecting dust under the bed untill i get the front mount done.
Literally!  Gotta get my act together  :P
could you explain the function of the bleeder valve.
I am the same ive had the intercooler for about 3 months now but havent gotten around to it until now. gonna do it all at once to avoid extra costs.
  Quote
They are NOT interchangable so as long as you order the one for your car' date=' you will be fine. www.nengun.com has been used by heaps of people on these forums, do a search and you will see. Very cheap and comes with warranty.
does the FC commander from NENGUN come in english or japanese?
  benm said:
I remember reading on here about 3mths ago that Mr Nengun himself said that replacement ECU's are classed as "(something)" which doesn't incur any import taxes.
The tariff code that nengun references is 9032.89.80
http://www.apectariff.org/tdb.cgi/ff3235/a...ind.cgi?AU+9032
  GTS4nMore said:
I Just Coped a $64 customs bill for a 2nd Hand power fc which was marked with value $400.
$20 Customs & $44 GST :(
can u dispute this with the info as quoted by ed previously -
" The tariff code that nengun references is 9032.89.80 "
http://www.apectariff.org/tdb.cgi/f...ind.cgi?AU+9032
decided to buy the system from nengun - total cost with delivery approx. $1100AUD. Thanx for all the advise guys - saved myself a couple of hundred dollars. Can now look into a better boost control.
Yeah I bought from nengun - probably ordered at the wrong time but it's here now - got a bit held-up from the Japanese holiday.
I also got the electronic boost controller and nismo adjustable fuel pressure reg.
nice - u gettin it tuned by a pro?
thats the go - I gotta travel to get mine done cos I live in such a limited area. I swear there is only 6 skylines in about a 150km radius where I live. we definitely stand out!! Does any body know much about evo in canberra?? Or should I go to sydney? I hear croydon are good tuners?
got my power fc and commander today from www.nengun.com - luckily I wasnt stung with any extra duties or taxes( as I have heard of) - total cost = $1,104.90 delivered.
now I would like to know if any one can recommend a good tuner in the canberra region.
thnx. :D
    • Why not? Since mines been built, I've used low boost maybe 5 times.
    • Yeah, so widen your search to any Nissan speedo first, then go wider if needed. I will say though, that there is a better than even chance that what I said first will likely come into play. They quite possibly won't come apart without damage. I tried to disassemble a stepper gauge that I wanted to repair. There was no way that needle was coming off the spindle, and I could not see how the spindle would come out of the mechanism behind. Assembled once, never to be disassembled, was my conclusion. Could be the same on the R34 cluster. Failing that - take the cluster to a workshop that specialises in automotive instrument work. There's usually at least one in every Australian city. They'll either be able to do it for you for small cost, or tell you it can't be done. It might be that "it can't be done" unless you follow some arcane procedure, including trickiness to glue it back together or something, that only experienced techs know.
    • Well, given that I, an engineer, almost never bring out the torque wrench to tighten up chassis bolts, despite fully knowing the theory, and instead rely on feel, which I happen to know is exactly how the majority of mechanics do things, should tell you the level of actual peril that exists from not achieving exactly 88 Nm of torque. How about if I just say then that 88Nm is at the lower end of the correct wheel nut torque range? Everyone knows how to tighten a wheel nut, right? And almost no-one ever brings out the torque wrench for that task
    • Don't be ridiculous. "2-3 ugga duggas or one Oof. You have to use Oof on tie rods because you can't get an ugga dugga on there." Is not helping the guy at all.
    • I have done a lot of research before posting here and on gtruk forum. couldn't find anything. I have my gauges all part except the needle itself. the needle has a extremely small hole in the center, but the shaft going to the needle is extremely small and appears to have nothing to index it either. doesn't seem strong enough to simple pry or pull without damaging something. Already tried the old spoon trick on a extra triple meter I have from a gtt, but no luck. the center cap comes off easily but the hole in the meter face plate aren't big enough to get over the needle itself. figured this would be my best place to find someone who might have actually removed theirs. wonder if there is some type of small pin press tool to push the pin in while pulling the needle base off.
