hi how are you
got a 1991 r 32 gtst front cut i have taken motor and gear box only
all pannels most interior parts
front bumper has electric motors in it to adjust front end
also got a/c pump and power steering pump
and projector headlights and side indercaters
suspenchion arms and hubs too
if any one need ne thing ask me
also a 1994 r32 gtr front cut left over parts most parts minus engine and pannels avalible such as front drive shafts cross member pedal box abs unit power boster and matser cylinders both clutch and brakes front sway bar lots more just ask
have compleate set of h/adjustable bilstien suspencion 4 r32 gtr 550 including freight ne were in aus all wishbones avalible and perf con front stering rack
also apexi pod adaptors 4 std gtr afm`s
r32 gtst parts
front bumper $200 with electric motors
steering colum calapsable type with ignition $100
std air box $30
a/c pump $150 with a/c rad and fan
power steering pump $80
speedo cluster $130
if ne thing else needed just ask
  • Replies 85
also a 1994 r32 gtr front cut left over parts most parts minus engine and pannels avalible suck as front drive shafts cross member pedal box abs unit power boster and matser cylinders both clutch and brakes front sway bar lots more just ask
bonnet per con no dents black in colour $200 ono
left hand side pannel per cont black in colour $100
std air box $30
speedo cluster $130
also compleat set of bilstien hight adjustable sus 550 compleat set
if ne thing else is needed just ask
cheers
The front bumper for the r32 gtr is that the front bar from the head lights down?? If so how much for freight to Melbourne?
:burnout:
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
