Hi guys im looking at buying a Skyline For my first car i want a R31 about but i want the TURBO got any advice on how to tell if the R31 is the RB20DET and the RB20DE im not that great when it comes to cars all i like to do is drive em oh and is there much of a power difference between the na and the turbo? i found a R31 1988 silhouette for Aus$2400 not sure what engine yet :P any help will be greatly appreciated.
Thx Brendan
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/
have you looked into insurance yet? for a 1st car, a turbo might not be the best option..
i don't think any australian car came with the 2L Turbo, just the 3L RB30E engine, for a turbo, you will need to find one that has been converted, or an import.. or do it yourself.. either way would expect insurance to be a killer
i am pretty sure the RB20DET have "ceramic turbo" written on the cross pipe above the engine..
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064651
Silhouette is the Australian built model and will have the RB30 engine unless it's been 'converted' to turbo which is unlikely for those sort of $$$
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064695
check out justjap for frontcuts, i know they had one a couple of weeks ago (it was a redtop)..
you wouldn't bother fitting a 2L non turbo, it would be gutless
your other option could be to drop a RB25DET into it :(
do a search here, or on r31 forums.. i am sure there is plenty of stuff out there
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064851
Even if you could do most of the work yourself a conversion wouldn't be the cheapest way to get a turbo. Motor, G/Box, ECU wiring, exhaust, brake upgrade, engineer's certification plus whatever labour etc $2.6K won't get you anywhere near it. You might manage to pick up a tidyish import turbo for $5K I've seen a few auto Passages (4door pillarless) go for that money. Manuals and coupes are harder to find for that money. A very tidy manual coupe with a few mods and some nice wheels probably won't leave much change of $10K
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064858
Your cousin should check out the car before you lay out any $$$...particularly the diff as they are prone to be very noisy/whiney (a known problem). Silhouette model should also have an LSD. R31's are solid, reliable cars when well maintained, but it's still 15+ years old and should be throughly checked.
[this is the part you won't like] AFAIC since this is your first car, you should get some experience with it in its standard (ie NA) form before going down the turbo path, not to mention the fact that getting insurance is going to be difficult and expensive.
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064864
Like it has been said,
The oz released R31 all came with an RB30E, about 114KW
The import HR31's came in RB20 Turbo and non turbo variants. The DET pushes out about 140KW+, while then N/A only does somewhere between 100KW - 110KW.
5K will probably get you an N/A import R31, coupe or sedan, but these are gutless as hell, no top end and no torque. You'd better off buying an N/A local R31, and save up money and mod that, or maybe do a VLT setup yourself.
You will be hard pressed to find a turbocharged import or local for 5K. Either fork out the cash for one already setup, or buy a stocko and DIY.
The other thing to think about is how you are going to maintain it? While 5K might get you an import, it will be barely there on the mechanical side, even still if you buy something else, theres rego and insurance to think about also, not to mention fuel costs.
Visit www.r31skylineclub.com you will find a wealth of information on the forums, just use the search function :( hope that helps
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1064927
If it's your first car, then the NA RB30 is fine.
I'm suprised that predator was the first person to mention turbocharging the RB30.
If you've found a Silhouette for that price, grab it while you can.
Drive it around for a while, familiarise yourself with the car, and then chuck a turbo on it
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1065068
spend a couple of hundred bucks on an advanced driving course, and just get use to the car..
better to have some money tucked away in case you find something wrong with the car...
then later on down the track look at upgrading etc..
https://www.sau.com.au/forums/topic/54361-r31-help-1st-car/#findComment-1065092
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
