have you considered buying that R31 then dropping in the RB30ET from the VLturbo? will provide PLENTY of power for you (probably more than an rb20det from the R32) even though its single cam it still has the extra displacement
it must be a straight fit as its the same engine and all the wiring/ECU is probably the same or very similar...
r31's handle like boats with 20yearold suspension, and from the sounds of your posts, your gonna wanna drive it sik and thrash the crap out of it in general. so if u have 2.6k left over
spend 1k on the suspension, 300 on some decent brakes (new rotors and decent pads), and keep 1k for broken things (in 6months you'll find out if your car brakes lots of things, or nothing at all)
spend the other 300 new timing belt, new oil, new plugs, new coolant, (new 02 sensor if the existing one is stuffed, like most are, if you don't replace this and yours is stuffed you can enjoy 16-20L per 100k's type economy, instead of 10L/100k)
thats the sensible but boring thing to do
the fun thing to do,
turbo your current motor, can be done for about 1.2k (DIY)
3" exhuast 600
FMIC 800
thats a fun way of spending 2.6k, but bluntly you'll kill yourself if your new to driving and kill yourself twice if you have stock suspension/brakes
thx for all the input guys i came got some xtra cash today dont ask how :cheers: but im gonna wait a while till a real good opotunity sticks it's head out :) and thx for the confidence Slow R31 lol dont worry im not gonna go over board but what would be the best thing to do to a RB20DET to get as much outa it for cheap? first things someone would do to it in other words just wana no for the future ;)
The best thing to do to the RB20 would be forget about it.
If you want to do it "on the cheap", the RB30ET is the way to go.
The RB30 is much easier to get big powergains out of for less $$$
The best thing to do is buy a stock R31 and just learn to drive properly. Stock R31's driven properly (even heavy ass boatlike TI's) have been know to run away from modded R31's on twisty roads because half the dickheads out there can't drive for shit.
Don't go and buy a car purely because it is quick in a straight line, you've a good chance of crashing it anyway, or losing your liscence. Wait until you're more mature before you get a quick Skyline
    • Hello! I'm new here, I have an R33 GTST that is currently being finished up! Last year was pretty rough, blew two stock turbos so I decided to build the car. Has been down since November, but I get it back next weekend!
    • Hello, I believe my car was imported to America in the 2000s by Kaizo Industries. Would anyone be able to help me find more info on them? I've only found all the basic stuff like that paul walker bnr34, them being shutdown by feds, just stuff like that. Any help would be much appreciated, thanks!
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
