1) pity it was moving
2) pity i was in a golf not a ceffy... :cheers:
but then, its okay i know this certain cefiro to arrive here in few months with rb26 and all the other goodies (including the tail ligths)....
quite conveniently, i seem to know where it will be kept too... :)
2) pity i was in a golf not a ceffy... :)
quite conveniently, i seem to know where it will be kept too... ;)
lmao.... not another one :cheers: looks like im selling just in time
  • 2 months later...
just pulled a mould of the tail lights of my old man's ceffy, once I get back home to melb I'll try to source a 4 door GTS tailight to then fit into that mould.... I'll have the ceffy with round tail lights yet :) I reckon the late model tail light looks pox, all the ceffies I've seen with the colour matched centres and the clear and red (no yellow) tail lights on the side look so much more stylish and modern... esp on a black car with chrome details.
