Could you please email it to [email protected] , i got it off Leigh a while back, but both of my copies have dissapeared and it would make it a lot easier getting the car back on the road.
its 24mb, too big for email.
I tested it and it was working, now its going html again... however, if you click on it to open it, it will (should, worked for me) open in your adobe reader, then you can click file save etc.
Let me know how you go, if you still cant get it, I'll give it to you on a thumb drive.
datto what side of town are you on... if you want my service manual let me know Ill put it on disk for you, I am belco way. Not even sure if it will help but hey, ill check tomorrow if I can zip it to fit into a 10mb file to be sent via email unless you set up a 1gig account with yahoo, gmail, or hotmail, check torrents as well there seems to be some fast software and manuals there as well.
I have a proper account with hotmail, i think its 2 gig, so it should be fine, but i live in Monash, so it would be easiest to get it off Michele. Thanks anyways.
Michele, ill give u a call when i get the chance. Thanks
hmm just browsing ebay for rims as i do and came across this vendor selling heaps of the Buddy Club P1 2 Racing rims in 19" for like $1200 wtf. I nearly bought a set of these in 18" when i had the skyline and i thought i was getting a bargin at $2k :P
either way seeing these for sale at that price makes me wish i still had my line :D (not sure why they are saying they won't fit a skyline without adapaters those offsets seem fine ???)
http://search.ebay.com.au/search/search.dl...&category0=
hmm just browsing ebay for rims as i do and came across this vendor selling heaps of the Buddy Club P1 2 Racing rims in 19" for like $1200 wtf. I nearly bought a set of these in 18" when i had the skyline and i thought i was getting a bargin at $2k ;)
either way seeing these for sale at that price makes me wish i still had my line :) (not sure why they are saying they won't fit a skyline without adapaters those offsets seem fine ???)
I bought a set of 18" jdm wheels a while back, they came off a JZA80 Supra. The back ones fit, although I would've had to roll the guards but on the front I would've needed fat spacers. Not sure what the offset was on them but they sit nicely on my brothers Supra now. :) (the b*#$*rd)
I'll probably regret putting this here lol but here's my BB Audition vid for anyone interested...
http://www.bigbrother.com.au/voting.html?memberId=518736
To nominate you need to register... takes less than 1min then you can nom whoever you want but can only nom a person once... just need to click "nominate for BB08!". you can also rate vids out of 5 stars...
You dont HAVE to nom me, but if you dont...
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
