Just ordered a Blazer Carbon Fibre Bonnet and Some Bonnet Pins! Cant wait fit it.
For those of you who dont know, my current stock bonnet had relations with my windscreen and my roof.
Its my first step inside the carbon circle, wonder if it stops there haha.
Nice... Carbon is the shizznit. :P
I hope you dont get defected and have to get it passed over the pits though...
I nearly went the carbon fibre bonnet when mine got damaged on a trip back from Sydney... Problem was I couldn't get any gaurantees from anyone as to whether it'd void my insurance in an accident especially if it shattered and cut someone.
So I went the boring way and got it fixed. They do look hot though!
just get a factory looking carbon bonnet that is painted the same as the rest of the car. light weight and stealthy.
So by that you dont mean Glossed raw carbon with big aggresive nostril vents like the one I ordered :P
Thanks shell :(
P.S. if anyone is after some www.skylinesaustralia.com stickers, ive got 2 that im not using and probably wont be using any time soon (wouldnt really suit on a ford?), if you want them let me know. theyre silver/grey, and theyre free! i dont know the sizes but theyre the smaller ones.
P.P.S Let me know if im not allowed to give these away, if there only for donating members etc...
:) I'll take those Beau
was that sarcasm? god Beau I didn't mean someone like you.. you're still around sometimes and are far from annoying.. I meant like a total random
Oh right, my bad...
hmmmm ill have to think about it... i ment any OTHER member would get them for free... :(
Call me when you want them or i can drop em over tomorrow arv...
would've but then i woulda had to have paid for actual customised plates :)
i did the best with what i had.
it was either that or RB 020 and whos proud of a stocker 20 ;)
GUS!! - You are a Skyline owner you should be proud of it regardless of what the motor has done to it!!!11one :P
I think you should have gone for - GUS R32 - that would have been cool ;)
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
