Bought some splitfire coilpacks on tuesday and requested Express postage. I received notification that it was sent on Tuesday and was given the tracking number.. YAY!
But..
..I tracked the parcel on Wednesday, and it says that it was only picked up on Wednesday, and is currently in transit to the Canberra depot from Brisbane. No big deal, I'll receive it today (Thursday).
Today I tracked the parcel and it's still in transit, and nothing was on my doorstep today. So, it was sent a day later and I can only assume that it has been sent via normal parcel.
Ahh well, not like my car is motionless in the driveway..oh wait, yes it is.
Cliffs:
bought coilpacks and requested express post on tuesday
seller indicated it was sent tuesday, but it was actually sent Wednesday
coilpacks should be here by now, but they're not
Assuming it was sent by normal freight
Mad.
Here's the first demo model of the clapper switch I've been building.
Hopefully I'll be getting it into production soon. Price somewhere between $50-$100, bepending on how cheap i can get some gear in bulk.
http://youtu.be/oZ2jm-RbseU
I've always liked the idea of having a clapper light.
For ages I thought only rich & successful people in movies had them but now normal folk can have them as well.
You know you have succeeded at life when you have clapper lights!
Got heaps done on the car today.
Everything is off the front, just need to get the cam gear and vct off so I can do cam seals and put everything back together.
Just need to get a seal puller tomorrow morning to get the crank seal out, that sucker is in there tight. Bent my pick trying to get it out,
Hopefully I can get it all done before 7pm tomorrow otherwise i'll have to finish it after work on Wednesday.
Inspection failed (of course). Points:
Remove all non-compliant window tint (the rear quarter windows and rear windscreen are 5%, lol)
Rear muffler fouling body (stock muffler I borrowed doesn't sit correctly - hitting underside of car)
Boot grommet missing (there's a 5cm or so hole in my boot floor under where the spare wheel should be - gotta get a rubber grommet to cover it)
Display all child anchorage points (FUUUUUUUUUUUUUUUUUUU need to have these installed and then engineered. Le sigh)
I'll just peel the windows myself this weekend I suppose, then book it in at Canberra Motor Works to have the child restraints fitted and engineered in one hit. Grommet can be found at clark rubber lol....dunno what to do about the muffler fouling though, it really shouldn't be since there's nothing that can be 'adjusted' in the whole exhaust system...anyone got a rego catback I can trial fit/borrow to see if it fits any better?
Easiest way I found for tint removal is steam cleaner. Just be careful using it around ur demister. Can lend you mine if you're desperate?
I might take you up on that if you don't mind mate, the only other way I've had tint removed involved a razor blade, Orange Power, and lots of time
that is such a shame, guess I'll have to hold onto this dangerous seat for a bit longer. How come they didn't point out the tint and restraints first go?
hahaha yeah if you don't have a problem with that :P just don't ruin it lol
    • 2 more things I have to work out Easy one first...can anyone describe how to pull the fuel pump and sender from a 33? I can feel there is some sort of mount and clips but don't have a manual and don't know the trick......if not I'll spend some quality time in the boot witha lighter tomorrow. Second question is harder.  He had changed the upper plenum to a plazmaman but clearly got to a point with the vacuum hoses where he said "f**k it, I'm going inside for a beer" and never came back to that job because it was a mess. Am I right to think that I need: 1. Pre throttle (16mm nipple on inlet) to AAC's main 20mm fitting as the main pre throttle feed 2. ACC has a second 13m outlet joined to that 20mm fitting which I think is the pre throttle air supply for the cold start valve? 3. Cold start valve's outlet fitting then goes to Plenum (to bypass throttle?) There is some adapter on the back of the ACC with 2 fittings (13mm and 10mm), do I run the 10mm through a 1 way valve to the Brake Booster (4) and the 13mm back to a 13mm nipple on the Plenum as the Idle control (5)? 6. Run a 6mm vacuum line from the Turbosmart BOV to the Plenum? 7. Run a 5mm vacuum line from the Fuel Pressure Reg to the Plenum? 8. Run a 5mm vacuum line from the Turbosmart Boost controller to the Plenum? (Wastegate already has a pre turbo pressure source running to the solenoid then the wastegate on the other side of the bay)  Any help appreciated, the GTR is quite different setup and while the Stagea also has FFP it is different again. (And no Dose, I'm not pissing it all off and putting a ethrottle on it....)
    • OK, onto some questions to try and speed up the process a little. Does anyone know what core this Garret is? I know it is a high flowed standard turbo but nothing else about it. Tag says OK 0169J - 446179-5032 Same question for the injectors, I don't know what they flow and ideally can work it out before it hits the dyno, they are a mustard yellow side feed
    • Quick side trip into the engine externals, alternator and PS were in place including tensioned belts, but the PS was dry (my guess is he had the steering rack reco-ed). Filled it up with Transmax Z but it will need more bleeding once the engine is running no doubt. BTW I've said before, I don't know what kind of soft animals you have in the city, but out here they breed the rats tough. I bet they were disappointed when they tasted synthetic ATF.... Coilpacks are Splitfires with a factory loom in reasonable condition. I didn't pull one put I bet the spark plugs are new as its a new engine
    • Onto intake pressure test. I have a Raceworks (damn brand thieves!) pressure test adapter that lets you apply pressure through a standard tyre valve and comes with a pressure gauge.....I just blocked off the other end immediately before the throttle body. Applied 30psi....and the turbo intake immediately popped off with a bang. Sorted that but it was still leaking, turns out there is a pinhole leak at the BOV adapter that I'll have to find a local place to TIG up. I'm sure it makes SFA difference with such a small leak but I want it to be right. Everything else up to the throttle body was good. Also cleaned and oiled the KNX cone filter, and this is the AFM if anyone can identify it (car runs a PowerFC)
    • I'll send you a message, but until I know what is OK (and anything that isn't) its kind of hard to work out a fair price. BTW I'm just helping out here, ultimately it is Mel's call what she accepts but I know it will go sooner or later.
