:( hoping it is just a leaky hose.
Either way Plenum out all hoses replaced.
Temp always under half way today. Leaks when turned off, not while on
No oil in water or water in oil (yet!!, touch wood)
Richard, I noticed today that your Exhaust and mine are the same (Blitz Nur Spec), but I have my silencer bung in.
All I need to do now is build a Fat GTR around it and I'll have your car. ;) minus the leak of course.
Fingers crossed she's all sweet (And I'm sure she will be!!).
Mine was on other side of the motor. I too had hoped it was just a fluid line or worst case a welsch plug but no such luck as confirmed when we got her on the hoist.
Do you have aftermarket temp gauge? Bear in mind by the time the factory one moves you're usually well f**ked and it's too late.
my zorst has no bung in the bung hole :D
and yeah - I was worried it would either go off the dial. Either upwards or downwards.
I'm Just relying on the factory one at the moment which as you know is either half or full or zero.
Kept one eye on it for any movement today. My PFC used to monitor water temp but haven't got the Haltech doing this.
Will have to get one in the triple gauge or hook a pc upto Haltech
Yeah - when stuff goes bad on a GTR it's normally really BAD
The may lose green fluid, but it doesnt lose turbos........
Yeah kinda pee'd on me a bit lol looked a familiar colour after drinking a few too many V's..... Warm too...
I just wanted it to be anything other than what it was... Coming out a crack on the side of the block.
Oh well. She's all sweet now! But I never want that feeling again.
Im going to set up an output on my haltech (maybe tomorrow if i can be bothered lol) that will display a bright red led when water temp gets over say 90. will also use this once i get an oil pressure and oil temp senders for it too. Once light comes on, pull over or its gonna be expensive lol. Would only require 1 output as well, just have a few conditions set!
Edited by k_d
Wouldn't you think maybe to set it at a little higher say around 100... Water temp is generally higher that oil temp by up to 10 degrees, when I give mine the beans it gets to a little over 90...
Just a suggestion
Yeah on average my water temp on the PFC shows 70-75 (depending on hot weather) and on my oil temp gauge it reads 65 or so.... Either way you don't want either of them creeping too high because that spells disaster..
Here be just some of the horrors that lurk beneath the plenum. There are more attached up under the plenum itself..........
That's not my engine, but gives you some idea
Thanks JD.
Going to be something/anything in the red circles below.
Definately Plenum off :(
Good excuse to get my Nismo on - woot woot
holds an extra litre of air and feeds number 5/6 alot better
Anyone heading out to the Nats for a look?? I have a season pass so I'll be loitering around. Will likely be in Braddon on the Fri/Sat nights too.
I'm keen to head to the drive in on the Thurs but have no idea if that's just for entrants with cars. Anyone got any idea?
It's like on the main screen at the main stage or something. Cars that aren't entered can't drive in but I'm assuming you can sit on the grass or somewhere to watch it.
They are playing Cars and Running on Empty.
Surely there's external speakers right? lol
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
    • Oh and how is the rattle when foot is on the clutch ?
    • Did you get the sport or track ? From what the documentation says the uniclutch has a small amount of movement to disengage.  So your story of tricky pedal setup seems common.    Hopefully you got it bled up too, as the bite point moving around is usually either plates wearing in or air in the line.
    • There's always "MIG it up and grind it back".
