Well they do say the best gift to give is one you would like to receive yourself. :D
You will need the plumber buddy.^
It aint hard Shell - just take up to an hour to do the lot.
$20 bucks max if you DIY.
Richard, I never knew you cared. What does a plumber charge to change an Oh Ring? LOL
Shell, yep it's not difficult as long as you can turn off the water, have a good sized shifter and the correct washers but mixer taps can be tricky.
haha snap... yep the water is the issue. No mixer taps.
Yeah, apartments may not have an easily accessible water switcherofferer. Might be central not individual.
If you rent, I'd be at least be contacting the Landlord if in doubt.
Look for a small panel or door in one of the walls,
Its probly in the laundry, or hidden in a cupboard or wardrobe,
There will be a tap, you may have to look around with a torch inside the wall to find it.
Or if it has an underground carpark they may be on the ceiling down there.
I have most plumbing tools, includung the tap reseater you will want for this job.
Ps spend the extra 5c per washer and get the good ones
Edited by D.I.Y. Mik
And...
Leave the taps open when you turn the water on to flush out the brass shavings,
closing the tap on shavings just puts a groove in the washer and they leak.
Hydroseal is a good lube for them, and you may need to seal the thread again with teflon tape or Lockseal.
Leaking spindles need replacing, they are cheap and its easier than refitting o-rings etc.
dads rule!
thats sick! i have a lazy mans 4 foot with just your average tropical fish lol. my dad has an 8 foot in wall salt talk with clown fish and shiz. but im way too lazy to put that much effort in
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
