14?! Take him to meets you grump ! Tenteen? Lolol.
ROFL! Get around aye Rob?
He also lives in Melbourne with that ovulating meatbag who brought him to term... :rofl:
I wish I got around many much mores... SLaArts !!! :wub:
  • Like 1
True. The inspection came back immaculate. The inspector has never seen a cleaner one in his career for R34 GTT's for its year etc ('98). there is nothing wrong with it bare tyres and break pads. So it turned out really well.
be careful it might be his mate doing the inspection
Maybe - the inspector was paying him out though haha. He said he is pretty filthy and has clothes everywhere in his car. Also, I picked a Melbourne based inspector as opposed to a Geelong based one (Owner lives in Geelong). Fingers crossed it comes out alright. We've agreed on a price and time of pick up - but no deposit was made (He didn't want one) - not sure because he is a nice bloke or because he is hoping for a better deal before I track down there (1.5 weeks away) - so I can't honestly say "It's mine". We've just agreed on a price and time of pick up - he is currently getting a service done on the car.
I can post up some pictures?
THanks : D!
Question regarding Air Filters - Can a SUS Powercore Type LM E4 Core 150mm fit a R34 GTT? Link: http://www.blitzpowerusa.com/products/suslm/suslm.html
I had a look around but couldn't find anything.
Who are you random? Race for pink slips? See you on the streets noobhead.
You almost had me? You never me, you never had your car. Granny shiftin’, not double clutchin’ like you should. You’re lucky that hundred shot of NOS didn’t blow the welds on your intake. Almost had me? Now me and the mad scientist gotta rip apart the block and replace the piston rings you fried. Ask any racer, any real racer. It don’t matter if you win by an inch or a mile, winning’s winning.
You almost had me? You never me, you never had your car. Granny shiftin, not double clutchin like you should. Youre lucky that hundred shot of NOS didnt blow the welds on your intake. Almost had me? Now me and the mad scientist gotta rip apart the block and replace the piston rings you fried. Ask any racer, any real racer. It dont matter if you win by an inch or a mile, winnings winning.
    • It makes you wonder, all these people starting to make a billet replacement head, I wonder if any have thought about trying to adapt tech from newer engines into them. You're already at the full design stage to make a billet head... Why not really spice it up and had some more modern tech into the mix too...
    • Connect all the plumbing up properly. The actual worst part about having the turbo unable to actually build boost, is you can and likely would over soon the turbo if you drove the car (free rev while stationary isnt likely to manage it).   If you do have an air leak as Duncan suggested, you'll have a bad time as the AFM will be saying different to reality.   As you have had the engine out, I'd go over all electrical connections again. If you have a consult cable, plug it in, and see what the ECU thinks is going on. Did you touch the timing belt? If so, double check your timing on the gears is correct AND put a timing light on it while it's idling and see what ignition setting you have. Is the AFM you've installed the one that was in the car previously? You said you replaced seals, what seals exactly? What have you had apart?   From memory when I had my RB25DET with factory throttle, there was two plugs the TPS plug on the loom could go to. One would leave the car running like shit, the other made it work, I think one plug on the TPS area was for something else (an option). It's too many years since I saw that part of the loom to remember properly though.   Is the car idling smooth (as smooth as an RB can)? Does it smell fuelled up?   I have a feeling either timing in timing belt is off, or a sensor isn't right.
    • Theres still skid pan and motokhana days up in QLD at least that are $100 or less. The ones that are ran as "driver training" less so, they're expensive, but just normal skid pan days like SAU ran are still low cost. And thats one of the places I learned to be a lariken, purely by asking for passenger rides, and how people were doing crazy things. Reese gave me plenty of pointers back in the day for skid pan! And yes Duncan, I will never forget your pointers for track work. Especially after Neil got out saying "I am NEVER getting in the car with him again!" 😛
    • 49719 is the cooler loop. Right at the front, LHS of that diagram. Return line from rack (LP side) goes to cooler loop on RHS front of car, then back under engine and returns to bottom of tank. 49717M is feed from tank to pump. HP line out of pump is thick rubber, followed by the hard line that runs down to crossmember and runs in parallel (but opposite flow direction) to the LP return line. Nothing goes anywhere near the firewall or interior of car. The closest they get to that is the connections on the rack.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
