Hope it clears up today. Wanted to go for a drive, maybe north side, and check out Rosie.
Friggin windy & rainy still but a glimpse of blue sky - hopefully blow over
It's sunny over this side - I'm heading over to Rob's (2mins from my place) and working on Rosie (Spark plugs) - Can go for a quick cruise-about afterwards if you're heading to the North shire Richard?
Having a suspicious engine cut out at 5,500 RPM in 3rd.
Edited by RosieR34
how much boost are you running?Im running 14PSI and its still alright for a 1.1gap.Im changing mine soon and not sure if i should stay with bigger gap as it gives a better spark or just go for 0.8gap
I'm running 14 PSI at 5,000 RPM and when it gets to around 6,000 RPM a MASSIVE boost increase happens - Rob can confirm this weirdness. However, the Engine cut out has been fixed after Rob and I changed the Sparkies. I think the gap was 0.8 (Rob can confirm).
Surely 14 PSI is unsafe - I was planning to get a R32 GTR Accularator (Spelling?) which will give me 10 PSI.
pretty sure you mean an r32 gtst wastegate actuator. It's the brass fitting that controls boost through the turbo's internal wastegate.
But unless you can easily find one, it is just as easy to use a standard actuator and a bleed valve to get 10-12psi. If you are running 14psi someone has already been fiddling with your boost control, but it's not really like an instant turbo death sentence
32 GTST Actuator. You talk to me...
I honestly think it is all plumbed in wrong and is bleeding all actuator pressure back into the BOV return pipe, therefore Not opening the Gate.
I thought maybe as 33 turbs seem to Splode over 12 psi maybe 34 OP6 turbs would possibly be the same safe level???
Edit* Are OP6s steel not ceramic?
um - not sure that's good value for money. Check through Cooma Diesel (GCG, Garret reps) the cost ....
I was quoted $900+ per turbs way back when.
New = $1250ea for -7's. Now they are $2300 a pair.
You may wish to join Erics GB on the HKS ss' when you find out the price.
He's doing a pair with full kit for $3k :D
(expect commission if he does Mr Deziner)
Edited by Sinista32
You guys totally lost me. So 14 PSI is too much and should be at 12 PSI.
What's this about rebuilding a turbo? Kinda want to avoid that.
EDIT: So 14 PSI max is okay - but to be safe I should be at 12 PSI?
Edited by RosieR34
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
