this ^^. Your other options are to get a -7 turbo or rebuild your current 1 for like $400? built to n1 spec so you can run heaps moar booooost. Your other option is to just get a blown turbo really cheap from somewhere and when you get the chance upgrade it to n1 and then just swap it over whenever you get the chance.
Edited by Anfanee
yeah scratch that. Pretty much new turbo or high flow the current 1. Both will need a tune so add another heap of cash there for a nistune etc. Just drop the boost down and wait till the turbo starts blowing smoke, then replace it lol
14psi is not guaranteed instant death for a turbo. It's heat that kills them so if you only boot it occasionally and for short periods you will probably be OK for a while. But 14psi would not be OK for regular, full throttle stuff like multiple drag runs or a track day where it has long periods of high boost and no time to cool down. I reckon NAP is onto it, there is probably a simple plumbing problem.
As for gtr turbs....n1 spec is OK if they are ball bearing (ie R34) but terrible if they are bush bearing R32, R33 or "nismo". They are still a pretty small upgrade, so maybe not worth all the hassle unless you are doing it yourself
um - not sure that's good value for money. Check through Cooma Diesel (GCG, Garret reps) the cost ....
I was quoted $900+ per turbs way back when.
New = $1250ea for -7's. Now they are $2300 a pair.
You may wish to join Erics GB on the HKS ss' when you find out the price.
He's doing a pair with full kit for $3k :D
(expect commission if he does Mr Deziner)
Of course! ; )
Actually there has been very little interest in it so far.
eyy guys just been noticing theres a higher theft rate of cars now in the ACT. I think theres a group thats started stealing peoples cars just as a joke. The shit thing is that my immobiliser plays up all the time. Anyone know of any fuel pump cut tricks or something to stop them. Ive just started putting on a steering lock thats only for overnights though as i park outside.
A steering lock sounds good. Might chain my car to the wall and purchase a pitball dog to sleep in the car overnight. I'm going to start parking around the back. Just a pain to get in and out. But atleast I can purchase a tent to cover it without looking like a nob lol
Edited by RosieR34
Switch in the Boot, on the Fuel Pump wiring would do the trick.
Not a Bad idea at all...
Im thinking about that maybe maybe making it wireless like how you unlock the car. Saves me the effort of opening the boot but if its gotta be done ill do it the hard way.
  • Like 1
Do we have any word on where these steals are taking place? North side / south side of even suburbs?
if you want an unobtrusive way to make sure it doesn't start, just unplug something important in the engine bay, but leave the plug touching but not properly plugged to it's normal place. The crank angle sensor plug, ignitor pack or resistor pack would all make the car crank but not fire.
assuming they aren't towing it away
So far they have mainly been going through the Northside (Charnwood). Been seen driving commonwhores (vn, vr or vs, a supercharged stato and a ute).
They got chased last night at around 3am but got away.
They are stealing cars and car related parts (wheels, turbos, front bars etc...)
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
