Other than the fact it's under finance, that's what I love about the van - ridiculously good on fuel (~1000km from ~57L), can carry heaps of shit and you can sleep in it.
Shame about the expensive part haha
yeah that is frustrating. I can connect the Leaf but neither the Cube nor Cima work, they must be too old for ODB2. PITA
Speaking of the Cima it finally arrived on the weekend, drove it down today (goes great, it's like cruising on a lounge chair).
cima.jpg.
But...there are 2 problems:
* check engine light is on (goes fine though)
* front brakes need machining
Is there a workshop in Canberra who aren't afraid of imports and have a consult 3 or similar tool that can turn the light off, and can machine discs? I'd prefer to get both sorted this week if possible.
Is it just me or do you have your lefts and rights confused. :D
Consult (Grey Plug)
My Bluetooth adapter is OBD and with an adapter cable will plug into my Consult port but won't connect.
It would be worth a phonecall... I've only dealt with National Capital Motors in Belconnen (mostly for Parts) but they do have a service center there too.
I should imagine they would have the appropriate Technology. :)
all sorted now, turns out a lot of the Nissan dealers think they can't do imports :blink:
just got a local guy back home to do the discs and turn the light out at the same time. it was an AFM warning but I am 99% sure it was only because I unplugged it while f**king around with the headlights
BTW is it me or did winter just start again?
    • I don't really know general street pads too well, but there is no reason you can't get a low dust, long wearing, no squeal pad that works for those calipers at a reasonable price....they would just be a low end to medium price daily style pad.  If new pads don't have much bite or they loose it over time, it is probably just the pad glazing up which you can fix by giving them a good thrashing every now and then (or get the mechanic to deglaze them at next service) Track or semi track pads are where you have to put up with excessive dust (and potentially squealing as a side effect of that) in return for good bite and performance when very hot. Street pads have nothing like that sort of punishment, even long downhills with the brakes on are easier than a track session
    • lol yeah I'll check that, reminds me of the LDV thread!  I don't think that is the problem here, the starter doesn't even solenoid click. I did do a super quick test by removing the starter motor's power cable from the engine bay fuse box and the battery voltage was still 10v, so something super fishy is going on. BTW here is a R33 fuse box table I threw together from a few sources....use at own risk! R33 Fuse Box and Sources.xlsx
    • Johnny's approach, throw all the Nissan electronics into the trash. Best thing I've done to my shit box, go DBW.
    • Sounds like the JAX guys must have installed some really awful pads, are they BenShit/BenDicks pads by any chance?
    • Result of another R35GTR build. Similar specs as above except this is running our bigger size SS-2 profile option. Made similar power except this car runs on Pump 98 fuel. Build specs are: Nissan R35 GTR 2015 model stock engine and box. ETS street intercooler boost logi intercooler piping with tial bov, boost logi turbo inlet pipe ID 1050 injector DW 300C fuel pump Decatted oem down pipe and y pipe& HKS exaust 3inch intake pipe Upgraded actautors HyperGear SS-2 high flow option Final result is 639whp / 477wkws hubs, Ron 93 / P98 fuel at 20psi.
