no issue there....you undo 2 bolts to take the caliper off the hub but you don't undo the brake line. Support the caliper so it's not hanging by the brake line, slip the disc off, clean the hub/disc surface and slip the new disc on.
Hmmmm...Considering giving this a go.
Any specialised tools required?
Yeah man do it! Read the DIY thread and have a crack. I did mine (First Time Ever) a couple of years ago, the last one took no time at all.
A bent up coat hanger is great to hang the caliper on to ease pressure on hoses and a bolt that fits in a particular threaded hole helps in the disc removal. Decent Spanner and a Rubber Mallet. Very Rewarding and the Slotted Rotors look Pertty but work so much better than the old stock scratched up discs...
Happy to assist... :)
They can be tight bastards, make sure to keep the wd40 off the pads.
Breaker bar helps, and some blue locktite when you put em back in is good.
But, yeah 2 bolts, easy as.
One thing i forgot...........
If the new rotors arent perfectly straight dont be surprised, its your old hubs.
The solution is get them machined ON the hub. And mark the alignment etc.
Edited by D.I.Y. Mik
Do you mean machining the brake face of the rotor or the mating face that mates with the hub.
You machine where the brake pads touch.
I have never done skyline brakes but done many of various cars so if you wanna hand and I'm free I'll come help and learn. Also I have a piston pusher backerer<---- yes that's a technical term lol
Thanks for all the advice and offers of help....which I may take you up on!
I ordered the parts today and they should be here on Thursday. Was thinking of doing it on the weekend but not sure.
My other concern is only having the normal car jack. Is this going to present any issues?
    • Seeing as it's an 04 model, I would be hitting up wreckers first.
    • No not yet.  Hopefully this weekend if I can pluck up the confidence!  I had to sit in the car at one point yesterday to unbolt the rear struts.  As mentioned in an earlier post when I was putting it together there is still a bit of rotation possible so when I sat in the car, it rotated a little bit.  I near shit myself thinking the whole thing was coming down!  I do 99% of my own shit in the shed but I think I might call on some assistance the first time I spin it!
    • Strong first post. On a Skyline-centric forum. Have you considered actually going out into the world, visiting the actual dealership, and asking the parts guy over the counter? Or at least just call them up on the phone?
    • Should shit that in as for the driver ability probably not
    • Trying to find the plastic under cover for an 04' Forester X. The main under cover that covers most of the front of the vehicle under the engine. This has turned out to be a crazy experience. Normally I can find parts for vehicles, if I have the correct info, no problem. But not this! The Forester is a non-turbo btw. In a Forester parts catalog, for model years 03'-06', it shows part# 56410SA070 as being the correct part. So I go to the local Subaru dealership's website to order it. I type in the part#, hit search and there it is, the under cover. "DOES THIS PART FIT YOUR VEHICLE?" I type in my VIN# and sure enough, "This Part Does Not Fit Your Vehicle. See Similar Parts For Your Vehicle." I click on that and part# 56410SA000 comes up. Looks absolutely nothing like the previous part. Not even close. So I go to a different Subaru dealer website and put in that 2nd part# (56410SA000) and "This Part Has Been Replaced By" 56410SA070, which is the first part I looked up. I thought OK, makes sense. They replaced the strange looking part, with the one I looked up first, so I add it to the cart. "Does This Part Fit Your Vehicle?" I type in my VIN#, and sure enough, "This Part Does Not Fit Your Vehicle." I've basically been doing this with various parts suppliers and dealerships, for the past 4 hours! Does anyone know what the hell is going on?? Thanks in advance!
