haha I like the social aspect of it. He got a new car and wanted to try it out on some roads so I offered the Cotter. He's idea, so I wouldn't go unless he was. Bank account frozen (no work) so fuel has to be used wisely :P
Just got news from iron chef that my car is on the way to compliance and should be there this week. They are installing new tires and band extender so I can pick up Aus radio.
Sooo close now
Where is pick up?
We should do a cruise in honour of Daniel and his new riiiiiiiiiide.
  • Like 1
mine took about two weeks get yourself a permit btw. NSW,ACT.I picked up mine from Melbourne so i didnt know i had to get a permit for NSW,VIC and ACT. Driving back got pulled over in NSW and they were meant to give me a $1200 fine but they let me go. Save yourself the hussle and get all permits.
Yeah right now I have paid about $13,500
Iron Chef quoted about $16,500 landed and complied.
So his guess is around $3000
They are fitting the cheapest possible tires for me because I won't be keeping the rims.
Also a radio band extender so I can pickup aus radio stations.
Room. I has none.
I think I'm going to investigate a storage unit for 4 months or so. Not an expense I need right now, but if it's not long term at least I won't be forking out for one indefinitely.
Storage, at least theres a bit of choice these days,
Cant build a shed where you are.
Was thinking the Bond roll bar thats FIA approved and bolt in might go well in the 32.
I can take it out for road use.
1/2 cage is probly the way to go.
Whaddayareckon?
$1015.00 six point roll cage with diagonal.... $670.00 1/2 cage with
diagonal
thanks 02 45879672
-----Original Message-----
To: bondrb@bigpond.net.au
Subject: R32 Skyline
Hi, im wondering if you make the removable roll bar/cage for R32 Skyline.
If so, what are the options and cost.
thanks, Mike.
Speaking of good locations .... here's a trip (with stages) I hope to be doing in the next few months if things go my way .. if they don't go my way I'll stick to going to doing a lap around the ACT, to Civic for a coffee then home :closedeyes:
  • Like 1
What sort of time frame do you expect to do this over?
    • I believe mine is helical and not clutch type. During drifting one wheel was spining as if it was open diff so bought kazz 1.5 way and has sat on my shelf for the past 5 years as I want to learn shiming process and do it myself   in meantime thought I change the diff oil hence post here. So any 75-90?   i am pretty sure r34 are helical not clutch lsd as standard . That is gtt ones
    • Throw between gears are so much that is getting annoying. I have pro short shifter on my mx5 and e36 and love it . Skyline is getting unbearable    would syncro issues and short shifter is no no? Anyone mind explaining a little on why before i buy cube
    • No. Well, some people "seem to use redline shockproof in the diff". Most do not. I would only contemplate it if you have badly worn CW&P gears. And no. No-one in their right mind has ever put ATF into a diff. Any normal diff/gear oil of the right viscosity will do. Whatever takes your fancy. Castrol, Nulon, Penrite, Redline MT range. Whatever. It's just gears. 75W-90 or 80W-90 is typical. I think that GL-5 is hard to avoid these days, although I think that a GL-4 is probably preferred, given the vintage of the equipment. At least Redline offer a number of GL-4 oils. If you have a clutch type LSD instead of the VLSD, then of course you need a proper LSD oil. Anything from any of the same names above. If you have a helical LSD, then it does not require LSD oil, and the recco is the same as for the VLSD. You don't want the LSD friction modifiers in the oil for a non-clutch type LSD if you can avoid it.
    • You may want to list it up for a little higher - This price is much lower than you may realize. Here you're pretty much selling to people who most likely already have these things on their own rigs. S chassis people eat this stuff up like you'd not believe.
    • I had my car for over 10 years and done around few thousand miles but never changed the oil. thinking of changing it.   what brand and viscocity would you put in ? people seem to use redline shockproof in the diff   on  contraty seen others using atf dexron 2 or 3 so wanted to check. is it 1 liter?
